Headlight replacement on F150,,,, |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13740 |
Topic: Headlight replacement on F150,,,,Posted: 30 Nov 2025 at 12:08am |
my 2015 F150 has to have the very worst headlights ever,,,,The lens on both front headlights look to have been "polished" to a point,, the lens are cracked and will not polish out for clearaty,
What brand have other members replaced the Halogen with,,,,?? |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34692 |
Posted: 30 Nov 2025 at 5:07am |
I just went with aftermarket the local body shops use. Nothing is available new from Ford, used is same as you already have.
Google search and toss a dart, all the same manufacturer just sold as different brand names. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5180 |
Posted: 30 Nov 2025 at 7:20am |
Yep. just like all of the parts pimps that sell the same offshore tractor parts. You're gona get the same part, no matter how it's boxed as there are extremely few companies in this country that actually make anything.
Trawler II
Joined: 04 Jul 2017 Location: Missouri Points: 3547 |
Posted: 30 Nov 2025 at 7:23am |
TYC makes good quality headlight assembly replacements. They’re not the cheapest, they do fit well and meet or exceed OEM. Google TYC headlights.
"Most people find it easier to believe a simple lie, than the complex truth"
Joined: 11 Sep 2009 Location: illinois Points: 88956 |
Posted: 30 Nov 2025 at 9:54am |
TYC headlights are made in several locations, including Taiwan, Thailand, China, and the Netherlands. The company, TYC Brother Industrial Co., Ltd., is based in Taiwan, where it manufactures many of its automotive lighting products for both original equipment manufacturers (OEM) and the aftermarket.
desertjoe
Posted: 30 Nov 2025 at 7:39pm |
Many Thanks Guys,,,now to hunt for the second best,,,,,
Posted: 22 hours 37 minutes ago at 9:57pm |
joe, you can buy new HOUSINGS that will eliminate the FOG problem.. Aftermarket are available on line in several sites...... The FACTORY bulbs are 55 watt Halogen.. you can buy AFTERMARKET bulbs that are also 55 watts... but you can also buy 65 watt and even higher, if you look around.. watts are not everything... Some bulbs have a better design gas chamber.. some give a WHITE light and some a YELLOW light... you might look for a BRAND NAME like "Sylvania super bright ".
![]() Edited by steve(ill) - 22 hours 18 minutes ago at 10:16pm |
Posted: 22 hours 12 minutes ago at 10:22pm |
Darwin W. Kurtz
Joined: 06 Apr 2010 Location: Westphalia, KS Points: 5222 |
Posted: 12 hours 2 minutes ago at 8:32am |
Someone told me recently,( and I have not yet checked on it), that at Wal Mart, you can buy some kind of stuff to spray on your head light lens that will take out the fog color - I don't know but thought it might be worth checking out before replacing the entire head lights.
DMiller
Posted: 10 hours 53 minutes ago at 9:41am |
Only works on face of lens, has no effect of crazing or discoloration within the
Plastic acrylic or the inside of lens. My 1999 was so bad as received the new housings I installed the brilliance with even to lamps had in old ones was immense. |
desertjoe
Posted: 10 hours 38 minutes ago at 9:56am |
So,,Dave, what brand of housings did you buy for your trk,,cost? How was the "fit',,? Did you also buy new bulbs for the housings??
DMiller
Posted: 10 hours 21 minutes ago at 10:13am |
Got mine off Parts Geek, reasonable pricing, came with lamps but tossed as had less than year old Ultra Blue Halogens in old ones, Like that Light as opposed to many others had in 25 years.
Really close fit, clips for the OEs had corrupted and had to buy new as the Tin Foil ones that came with were less than adequate. CAR ID has a Similar line and know two that bought theirs there, also satisfied. Edited by DMiller - 10 hours 19 minutes ago at 10:15am |
desertjoe
Posted: 4 hours 7 minutes ago at 4:27pm |
Well,,,after lots of reading and surfing ..I've just about decided to give the PIT66 housings from Walmart a whirle for price and delivery. Someone correct me as to the designation of the H11 and the 9000 bulbs,,,? Are the H11 for the high beams and the 9000 for the low beams OR,,,?? It seems that the low beams are used more frequently but the H11 are mentioned more frequently,,,,?? Don't give up on me just yet,,,,, By the way after many searches,,,I did not find any bulbs other than the 55 watt,,,,
Posted: 3 hours 35 minutes ago at 4:59pm |
H11 and 9005 are two of the most commonly used automotive headlight bulbs, but they are not the same. Standard 9005 halogen bulbs draw slightly higher wattage and produce brighter light than H11 bulbs. Because of this, 9005 bulbs are typically used for high beams, while H11 bulbs are more common in low beams and fog lights. Many vehicles with dual-bulb headlight assemblies use this exact combination.
Edited by steve(ill) - 3 hours 35 minutes ago at 4:59pm |
desertjoe
Posted: 1 hour 44 minutes ago at 6:50pm |
Well,,Many Thanks Steve,,,!! I been wondering about that little mystery,, so now I know,,, ![]() I did notice that one of the bulbs is bigger than the other,,,? My trk has the upper (hi beam) and the lower,,(lo beam) but the higher bulb sits behind a "difuser" or "broadcaster" of sorts and the lower bulb is just straight out. Many THANKS for all youse guys help,,,,!!!!!
desertjoe
Posted: 1 hour 15 minutes ago at 7:19pm |
Well,,I thought I was thru,,,but I ain't,,,,The headlight replacement (PIT66),,,I had settled on was from Walmart BECAUSE it was the only'ist one that mentioned the crew cab but I really have NO IDEA why the cab would require a different headkight,,,!!! NOW,,I cannot find the freaking item to place my order,,,chit,,,chit,,,chit,,!!!!!
