HD5 Track Bolts
Message Reverse Sort Order
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: HD5 Track Bolts
    Posted: 10 May 2025 at 9:55pm
Thanks to all for the pointers, I will check them out. Smile
Ages Cat View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 11:41am
The last four I needed came from CAT.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 2:18pm
Yes track bolts are different from standard hardened bolt , both in shank size below head as well as head itself , then nut for bolt also differs .
 And Hardware store bolts of grade 2 , grade 5 and even grade 8 are not going to work for long , same for nuts as track nuts are square in many cases and also longer thread area , but are sized t  be captive in track link
Edited by Coke-in-MN - 09 May 2025 at 2:35pm
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
CAL(KS) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 11:10am
lots of aftermarket places out there have track bolts.    i have purchased for HD16 and HD20/21 track.   just hit up google and pick what you want
Ray54 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 10:43am
The world keeps moving on, an this old guy does not.
But anyway Caterpillar use to have a on line publication called
  One Safe Source     had all their hardware listed
At one time 40 years ago Cat hardware was the best and in many cases cheaper than than lesser products. But from things on ACMOC some dealers seem to price it high to keep incidental business away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2025 at 9:38am
Originally posted by orangeman orangeman wrote:
Check with ITP - Link here:https://industrialtractorparts.com/
Last I knew they had a shop in Wisconsin, one in near NYC and in a few other states.
~ Orangeman
Thanks, I will contact them.
orangeman View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 4:48pm
~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 3:09pm
My Son-in-law's HD5G had a couple of track pad bolts come loose so he bought a few used ones from General Gear in Boise. So far so good, but they didn't have very many available, and they said that normally they just torch them off and don't attempt to salvage track bolts.
I have an HD5 Parts Manual, and it lists the track pad bolts as 1/2" NF. Yes, the threads are indeed 1/2" NF, but the shank of the bolts measure right at 0.530", or roughly 17/32".
The original bolts fit quite snugly in the holes, and a standard 1/2" bolt rattles around fairly loose.
Does anyone know of a source for new, correct bolts for these machines?
Edited by Les Kerf - 08 May 2025 at 3:10pm
