GM transmission shift cable |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42095 |
Topic: GM transmission shift cablePosted: 17 hours 60 minutes ago at 11:17am |
Seems my 2010 GMC shift cable dropped off lever that operates the selector on transmission 3 times in last week .
Replaced the bushing with Dorman repair kit and 2 days later it fell off again . The small tang on the operating arm is suppose to snap into nylon bushing but seems to come loose with little or no effort , shifting in or out of Park is enough to dislodge cable . Now wondering on a repair that keeps the cable attached as this crawling under truck to put cable back in place is NOT a Easy Fix when in traffic areas . Clearance of arm to transmission case if using a bolt in unit presents a clearance problem unless welding and drilling is done . Wonder if GM has a actual FIX or recall on this problem - Truck only has 30,000 on it but 15 years of age , but new bushing still fails |
DanWi
Posted: 17 hours 3 minutes ago at 12:14pm |
On my !999 3500 the end of the cable broke down by the transmission. I took a small piece of metal and made a little splint that wrapped around both ends of the broken piece. Then used zip ties to hold it together. Ran it that way for a few weeks till I got it fixed. Dot a new genuine GM part on Amazon in less than 24 hours. The new cable goes to the back thru the tunnel then under the driver's seat then forward to the firewall shifter. It wasn't a job I wanted to do so had my local garage fix it, They were familiar with it and also found a bracket under the steering column that cracks. They took that out and down the street to have that welded up. Its weird because the column shifter has no detents they are all in the transmission so your shift lever just falls down. That's the problem with new stuff made cheap and out of plastic. Remember the old shifters that had a rod going right to the transmission with a metal ball joint on the end.
Edited by DanWi - 16 hours 60 minutes ago at 12:17pm |
Joined: 11 Sep 2009 Location: illinois Points: 89201 |
Posted: 16 hours 6 minutes ago at 1:11pm |
if the new bushing can not be retained on the original arm / stud... then you probably need to remove the arm, replace the stud with a bolt and nut...
Coke-in-MN
Posted: 13 hours 60 minutes ago at 3:17pm |
What I was thinking of doing is using a bolt and washers , weld bolt to arm and lock nut on threads . As I have one truck in shop and have to do the work outside , it might have to wait . See you can buy a new arm (Dorman 74125 Shift Lever Arm) for around $11 but wonder if that would be the fix or use tie wraps for now until it gets warmer to work outside .
Again the curse of not building the shop big enough to get more than one vehicle in . 32 x 45 use to seem large enough - and then THINGS filled it up |
Dakota Dave
Posted: 6 hours 38 minutes ago at 10:39pm |
I have a 2012 should be the same as a 2010 it has a very small C clip thatholds the plastic bushing on the shift laver pin look resl close it dould hsve s groove in the pin it was a hassle installing it good thing they come in a pack. Got mine from Amazon O'Reillys didnt list them. Just serch sit retainer clip. Mine fell off 3 times till I got to O Riellys and put a small hair pin on it was all they had worked till I ordered a C clip and installed
Walker
Posted: 6 hours 14 minutes ago at 11:03pm |
Them automotive engineers have only had about 140 years to perfect it. This complicated stuff takes time. As long as all your cupholders are still working, that should cover the 80 grand you paid for it.
Coke-in-MN
Posted: 5 hours 30 minutes ago at 11:47pm |
Walker - SO TRUE but a plastic bushing is cheap - just because it breaks is a small problem - until your setting at a gas pump and 10 cars are waiting to get to the pump .
That stud on the shift arm is turned down on the end - would have been a real hard thing to have hole drilled in it and cotter pin installed |
