getting bolt out |
Tim in arkansas ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: Charleston AR Points: 191 |
![]() ![]() ![]() ![]() ![]() Posted: 19 May 2012 at 8:28pm |
I been working on my 1940 model B and I have trouble I got one bolt that holds the steering box to the tube the other bolt the threads are stripped and will not turn I have tried everything so can I cut the bolt off and drill a hole and use an easy out to do the trick? thanks
Allis Chalmers fan from Arkansas
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
If the bolt is siezed in the hole I'd say drilling and easy out won't work very good. If you can get a little heat on the outside of the bolt without cooking anything it'll likely come out.
Yea, I can fix that.....
thanks
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41979 |
Cut the head off , leave the bolt sticking up , weld a large nut to the bolt shank then wrench it out
tomNE ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: dorchester, ne Points: 1225 |
welder
AC from the start of my families farming career till the end!
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24651 |
I did a 'modified' version of Coke's method.
I put a washer on first THEN weld a nut onto the busted bolt shaft.
Let it totally cool BEFORE you try to undo !!!
The washer gave me some wiggle room with the AC stick welder and my 'nervous' handiwork !!
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
After welding, wait till things aren't cherry red and start wrenching. I never wait till it cools all the way down. Heat is one of your friendly tools in a situation like stuck bolts.
Edited by CTuckerNWIL - 20 May 2012 at 6:51am |
David Maddux ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 2535 |
If the bolt is big enough, I drill the center of the bolt with a 1/3 size drill bit, then reweld the drill hole with qw wire welder, then weld a washer on. As it is cooling down, apply a candle to the threads. Then you can take out with a pair of pliers.
MBWisc ![]() Silver Level ![]() Joined: 13 Apr 2011 Points: 103 |
If that fails, drill and tap new treads.
that wax method works well , a candle or even a old color crayon applied along side the hot bolt, allows the wax to seep down into spaces and lube the rusty threads.
