Centering a Wheel
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Centering a Wheel
    Posted: 08 May 2019 at 1:56pm
Last time I adjusted my wheels in (190 power shift rims) 1 side is not centered so I get the wheel out of center up and down going down the road
Easy way to center wheels?
Charlie
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 2:47pm
Yes that can be tricky. To get the power shift inner centers to rail in or out, it’s outer clamps require adequate loosening. So once you’ve move the inner center & it’s time to re-tighten their outer clamps, EVENLY tighten the 3 & 9 o’clock clamps ONLY first. Then, rotated the whole wheel 90 degrees. This places the tightened 3 & 9 clamps at 12 & 6 position? Trying to remember if 190 has 6 or 8 clamps? If only 6 clamps, then I guess 3 & 9 position would only rotate up to only 11 & 5 positions?? Once there, tighten the other 3 & 9 positions. Again, tighten them EVENLY. Continue tightening in that style.
Edited by AC7060IL - 08 May 2019 at 2:54pm
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 8:03pm
I  always had trouble with mine. Will have to remember that. I always started with the top and botton.
