WD oil pan gasket installation
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: WD oil pan gasket installation
    Posted: 17 Jan 2011 at 6:53pm
Just a quick question...
When installing the new gasket set for the oil pan on a WD.. Whats the normal length you guys leave the thick gasket on both ends (front and rear mains) above the height of the side gaskets? About a 1/4" or 1/8"? What do I need to do to make sure I got a good tight seal around the mains?
Thanks!
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 6:56pm
           Don't cut anything off or you will have a leak. Others will post soon and they will tell you not to cut them off.
                                          John Carlson
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 6:57pm
 do not cut any off of them or you will have problems leaking!!  have seen it happen
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 7:01pm
What a timely question! With a little luck, I too will be installing a pan gasket soon. I am glad I read this, I might have done some trimming that I would have regretted later.
I sure do like this website, and I sure appreciate the knowledge that is shared here!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 7:23pm
Don, Please don't cut them off, the guys are spot on about this!! Get a old soup can and clean it up then roll the end gaskets inside the soup can and leave them there for two or three days, the end gaskets will fit the pan and retain there shape from the can, use the little clips to hold the ends in place and don't use a lot of sealer on them.
hope this helps. Here's the can I use.
Don(MO)
Edited by Don(MO) - 17 Jan 2011 at 7:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 7:51pm
  piece of 4" PVC PIPE WORKS GOOD ALSO FOR OVERNITE  CLAMPING
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 7:59pm
Don(MO)
Whadda ya use the salt for?
Edited by redline - 17 Jan 2011 at 8:00pm
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 8:10pm
Some kits come with small clips to hold the front and rear gasket during installation. The A.C part number is 70229177 and when I did mine last summer it was a big help. Don and other members are right on about the can trick for getting those gaskets to work.
Danny
P.S. I agree don't cut anything.
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 9:01pm
Thanks guys!
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 9:03pm
for those interested the NAPA number is FPG OS30130C (Fel-Pro brand), which also includes the clips
Allis Wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 10:59pm
Bill, I know this forum is 8 years old now but are the Napa gaskets as good as agco or elsewhere? I’m doing the pan gasket on my wd45 now.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 8:06am
If still available, Felpro's are always good gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 10:17am
Will the NAPA Felpro kit work on a wd45 too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 1:35pm
Yep, still available. WD45 is same pan and gasket.
jboettcher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 10:51am
It appears FelPro makes a 1-piece neoprene gasket for a WD.
Does anyone know anything about this item?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 11:55am
Go to the farm equipment-knowledge base forum. There is an excellent post on exactly how to do it!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 2:33pm
Anyone ever try one of those one piece gaskets?  Looks interesting.
AaronSEIA
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 9:01pm
AaronSEIA
Put one in a big block Chevy three or four years ago. So far so good. I did this in chassis so a four piece set would have been a nightmare. No experience with the WD set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 4:57pm
Update.   I fixed a leaking oil pan on my WD without a gasket.   I used Right Stuff from Permatex.
I went to a engine machine shop and told them what I was doing, and they suggested Right Stuff.
It’s very heavy bodied and you need to work quick. I let it set up overnight and I’ve run in an hour so far with no drips.
(And I wasn’t chasing 4 pieces of cork around)
Just a heads up, it makes life easy
