Cultivating with a C
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Topic: Cultivating with a C
    Posted: 05 May 2019 at 3:17pm
Can a Allis C be set to cultivate 48” rows of corn? We had it planted by a neighbor with a cub and planter.
We have a Allis C and a set of cultivators that have never been in it. I was wandering if we put the cultivatirs on the C would it cultivate rows that wide, even if we had to only use one side and not both sides.   Could the tires be adjusted to the correct width to do one row at a time
The cultivators that we have are not in good shape and would take a lot of work to free up and install, so I thought I would ask here if it was worth going to the trouble of fixing them and mounting them ?
Any help would be appreciated, Thanks
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 3:52pm
I am of no help, but I think that’s interesting. A lot of farmers around here plant on 40” rows, but I’ve never heard of 48” before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 4:00pm
It is awfully wide rows, but it was how he had his cub set up with his planter, and it sure went quickly, especially since I would have had to plant it entirely by hand, so it was a big help.   However that leaves me with the problem of side dressing it and cultivating it when it comes up.   Was really hoping I could use my C to maybe do one row at a time, just hate to put my C and cultivators together and find it won’t work.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 9:39pm
I don't know either but we used to do 42 inch rows with a WC but I think that was about as wide as it would go.
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 10:07pm
Idk about a c but, there a lot of people around here use just one side of a supper c farmall for cultivating tobacco and other crops that was planted with a one row machine. I would think if you follow the row with the front cultvator set the rear to reach out into the middle of the row it should work.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 10:26pm
A one row on a B will do it!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 7:02am
The book for the #80 C cultivator says 26-44".
AaronSEIA
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 7:18am
How tall of corn would you eventually want to do?  Any way to remove some sweeps, straddle 1 row with a rear tire, and sort of do 1/2+ of a row at a time, finish the row on the way back????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 10:33am
Thanks for all the replies, I think I’ll go ahead and mount the cultivators on the C and see what I can do with it , maybe one row at a time and use the rear to fill in some to.    But first. I have to take the Woods mower out from under it, but Ii’ll give it a try and keep y’all updated on how it does.
The cultivators haven’t been used in years, may be a challenge to get them operating smoothly again.
Also my hydraulic pump has quit working, will have to remove it and see what’s going on with it.   IThe pump quit about 15 years ago and I had to remove it and free up a stuck plunger, I hope it’s something similar this time , it worked fine after that till last fall and stopped picking up the mower deck at the end of mowing season.
But y’all have convinced me to give it a try,
Thanks for the suggestions and maybe I can post some pictures in a month or so.   This forum is always super helpful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 11:10am
If you need help getting the cultivator on, shoot me an e-mail.  My 11 year old has one on his C and I've gotten good at putting it on and off.
AaronSEIA
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 4:23pm
Mine (1948 C, #80 cultivator set)  is set for 36". Up front I could move the trapazoidal carrier outboard 5" each. That would get 46" rows as a double row cultivator. However, the oil pan for the final drives drop down will be whacking taller crop, I think 44" rows would be cutting it close with the oil pan issue, and also the final drive casting inboard face, where the draw bar mounts, if the corn is tall.
To get 48" double rows. First now you are about dead on center with the final's oil pan. Then the shoes need to be slid to maximum further back (&outwards) on the tool bar.  The tool bars are not equal length I think you can install the longer ones outward to gain even more. Sort of looks possible. If the corn is short.
As a single row I don't see a problem. However I didn't think through tire spacing for either scenario.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 4:45pm
Does the neighbor with the cub have a cultivator set up for his cub. Maybe you could ply him with some beer and or ? and gas to use the rig a few times a needed.
