I600 Loader check valve part number needed
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: I600 Loader check valve part number needed
    Posted: 13 May 2014 at 11:50pm
Does anyone have the part number of the check valve that is located in the small hydraulic return reservoir that is welded to the ladder frame? The reservoir that I am referring to is on the backside of the control valve.
I'm just missing this part number to place my order, I believe the information is the loader service manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 11:58pm
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2014 at 7:39am
There are parts manuals for the AC Industrial on the MINPar site. Here is the ink fo r the I-60
.http://www.minnpar.com/partbooks/Allis%20Chalmers%20Light%20Industrial/I-60%2C%20I-600%20PM%20%231012420.PDF0.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2014 at 10:01pm
Thanks!
The part is NLA, so in going to see if I can fix this one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2014 at 10:37pm
I took the valve apart and got it moving again. What does this valve do anyway? Also, how does it work, it seems like it may be missing something as pushing on it doesn't seem to open anything, it just moves the rod upward. Any thoughts or guesses?
Edited by Dean (West MI) - 18 May 2014 at 10:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 9:36pm
BTT (back to top). :-)
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2014 at 8:11am
Did you get your answer yet? If not I will try to explain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2014 at 10:15pm
No answer yet Rich, I'd appreciate any insight as to the function of this item.
Thank you.
This page was generated in 0.081 seconds.
