D19 gas governor
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Topic: D19 gas governor
    Posted: 01 Jul 2023 at 10:56am
Was removing the timing cover to replace the gasket and when it came off the governor came out also. My first question is do the gears need to be timed any certain way or can I just stick it back in there? My second question is I noticed one of the ball bearings is missing from the thrust bearing. Is it safe to keep using this one or would it be better to replace it? Hopefully they are still available if needed. Thanks.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2023 at 12:11pm
Shouldn’t need timed. I would replace that thrust bearing if I were you.
ryan
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2023 at 12:17pm
Look in the oil pan?
probably not there, might have gone out in the oil change...
might have fallen out when a mechanic had it apart before...
or as it was being assembled.
Don't know if it makes any difference for the slight out of balance.
 Guess I would replace it.
This page was generated in 0.139 seconds.
