AC Planter Question |
Garrett2006
Joined: 09 May 2018 Location: North Carolina Points: 40 |
Topic: AC Planter QuestionPosted: 29 Apr 2019 at 5:54am |
What keeps the planter shoes/seed drop tube from clogging with dirt? Or is this common problem with old row planters with shoes instead of disc openers? Thanks
Kurt WI
Joined: 19 Oct 2011 Location: Cascade WI Points: 3246 |
Posted: 29 Apr 2019 at 6:25am |
It was with ours when it the ground conditions were not quite dry enough. When planting we tried to keep it moving other than stop and put it down. Seemed to help some.
WD D17D 170 190xt 190xtIII 200 7020
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3202 |
Posted: 29 Apr 2019 at 6:46am |
Be moving forward when you let it in the ground and keep moving when you raise the planter out of the ground.Don't stop with the planter on the ground.
JoeO(C-MO)
Joined: 12 Oct 2009 Location: 3rd Rock > Su Points: 132 |
Posted: 29 Apr 2019 at 6:51am |
As already mentioned, keep moving forward when raising or lowering planter.
This also applies to planter with disc openers.
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts. |
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2736 |
Posted: 29 Apr 2019 at 8:00am |
...and never, ever back up with the planter in the ground...
