HD11E rails/pads
HD11TEX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD11TEX Quote  Post ReplyReply Direct Link To This Post Topic: HD11E rails/pads
    Posted: 14 Aug 2018 at 10:07pm
Anyone have any rails and 20” grouser pads for HD11E
Edited by HD11TEX - 16 Aug 2018 at 6:25pm
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 1:02am
Thats a nice looking HD11E.
Is a late one too; as has the later air cleaner assembly.
F50 winch too; very nice .
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 1:03am
Don,t be shy with some more pics !
rickv57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 10:01am
Looks like a very nice tractor and, I have one just about like it
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 11:35am
If you can't find HD11 track the D6B use 6.91 inchs pitchs
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 11:55am
Another here on the forum had posted the Cat conversion p/n's for the change to 6.91 rails. Darned if I can find it now. Had I not found the rails for my 7G would have gone that route.
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 2:40pm
The HD7GB use too track 7 inchs pitch
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 3:01pm
I think that is D5 Cat that is 6.91 pitch. Cat has sprocket rings to use or convert the older D6 that was 6.5 pitch to the 6.91.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 4:25pm
Found this as a earlier post to change to 6.91 (6.906) rails:
http://www.allischalmers.com/forum/hd-11b-sprocket-segments_topic144440.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 4:31pm
A quick look at the head on photo shows the same wide spaced set of track shoe bolts, this one may have already been converted.
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2018 at 8:33pm
from the look of the grouser height  on your dozer you don't need track shoes  Shoes last several times through track chain replacement  Have a local construction eq dealer measure your  u/c which they usually do for nothing for the opportunity to sell you the u/c.  You may not even need track chains.
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2018 at 12:35pm
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2018 at 1:20pm
Seriously doubt are 75% but just having a spare set WITH segments is well worth that price as they are currently NOT available otherwise.
This page was generated in 0.081 seconds.
