Allis Chalmers 7030 radiator in a 7020
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 7030 radiator in a 7020
    Posted: 19 Jun 2017 at 5:49pm
Is there any reason a 7030 or 7040 radiator wouldn't bolt in a 7020? Ours is an 1981 model if that matters. I see there is a serial number break at 6000 S/N on the 426 equiped  7000 series. Is that a change in oil cooler? Also is there any particular place to buy one other then Shoup ,Tractor Joes or TractorPartsASAP?
Edited by fourthgeneration - 19 Jun 2017 at 5:53pm
sason View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sason Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 9:14pm
301 engines had ac compressor up top where 426 had them on oh side of engine. 426 radiators have top tank spout in middle where 301 spout is to the outside more. And when I say spout I mean where top radiator hose hooks on.
180 with a turbo and 460 loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sason Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 9:18pm
pictures for example one that had fan damage is from a 7020 where other one is from a 7040
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 9:36pm
A good radiator shop can move the spout over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2017 at 7:23pm
Thanks for the info.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2017 at 11:10pm
when my 7020 rad went bad; no one even hinted that it would take a 7030 and up radiator.   i'm thinking it's way different.  it might fit the other way.  7020 to 7030 a hole lot easier.
AC from the start of my families farming career till the end!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 12:36pm
It looks like there are no new radiators available for the 7020 model. I found one for the 7000 and the 7030 and up. I'm hoping the radiator can be rodded out or the tanks are good enough to recore. Other wise it will be moving the inlet on a new 8030 radiator.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 2:15pm
I put a new 7060 rad. in my 7020 highcrop. I only had to move the shroud up a inch or so. The long top hose will match up good enough to the top rad spout.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 11:55pm
What about A/C compressor interference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 8:54pm
If you have A/C, the hose will not fit. I looked at my 7010. There is only a few inches space between the clutch and the radiator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 11:02pm
7000 should have the same radiator.  301 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 4:54pm
The 7000 holds 3 quart less than a 7020.
