Allis b water pump seal?
ryanschott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Topic: Allis b water pump seal?
    Posted: 23 May 2017 at 10:01pm
I have a 1940 b and the water pump was seeping water out the seep hole so I have a few other pumps I took off parts motors and both of them seep water even more then first pump. But other then that they work fine. So question is can I replace the seal and how and if so what seal number do I use. Would be cool if I can cause 1951 Ca leaks too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 10:31pm
It is possible for you to do it but it can be challenging.Need a press and select odds and ends to support and or push through in the process.Home made stuff works since you likely don't have "proper tooling". Haven't done one of those so can't say but usually involves pulling fan hub,looking for hidden snap ring in nose and pressing of impeller.Cast impellers can break,housings can break,etc,etc....AND everything has to be pressed back in the correct correlation.Nothing ventured,nothing gained.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 10:36pm
Look at in agcopartsbooks.com    You can usually buy rebuilt with guarantee for a little more than the kit
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 11:30pm
I have the tools and presses at work just I'm broke more then the pump otherwise I would buy a new one. Just wondering if I could replace just seal and what kind of seal is it
This page was generated in 0.057 seconds.
