Building a 7000 series high clearance
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Topic: Building a 7000 series high clearance
    Posted: 13 May 2017 at 8:05am
I may buy an early 1974 model 7060 Power Director to start this project. I know where two original high clearance parts tractors are. One is a 7045 and the other is a 7020. After looking at Parts Books a bit can I assume the the drop housings from either tractor would bolt up to the 7060? Both of the doner tractors have nice front axles and that part doesen't worry me as much. They are both half cabs which I am leaning towards too.
I am building this to use. I grow a little tobacco and need the clearance.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 8:22am
do they use final drives like on the 100 series?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 8:38am
Shamless it's what down here is referred to as a drop housing. AGCO parts books shows it much better than I can describe it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 8:50am
I understand...here they were called final drives...like what are on combines and the 100 series like the 180. I was just wondering. I've never been around a high clearance cept one of them high 4 post 8-9 N's.
Dale-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 9:06am
All of the factory High Crops I have seen are Power Shift Transmissions. But I don't think there is any reason that you couldn't use a power director tractor as long as your not worried about being factory correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 9:38am
It basically give you about another foot of clearance. I fon't have any good pictures but Google has a few.
I admire the guys that can put them back looking like new but this one is for me to use so I going to do it my way. Probably paint the belly black too. I never did get the maroon/orange thing.
acben20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 11:04am
All 7000-8000 series were power shift
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 1:49pm
AND SOME WERE Power Director
Edited by Fred in Pa - 13 May 2017 at 1:49pm
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 6:29pm
I am no expert on anything but I could swear someone on here owns one.
No one has shot down my plan so far so I guess that's good. Next step is to buy a running tractor and then get the high clearance parts and dive in. Should be a fun project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 7:16pm
I have both a 7000 and 8000 tractor and both sales adds for both and it says power shift trans standard with high crop tractors..
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 7:21pm
Well standard means standard. I'm thinking you could order whatever, maybe. Someone here had one and they said it was factory and someone else commented that it was rare. I'm not sure if that would add much value but who knows.
Sagefarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sagefarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 8:03pm
I am interested in your project and would like to have one for cultivating a specialty crop. Will you have to do something to the lift arms, or is that a part from the hi crop tractor. Are the hi crop donor tractors common in your area
AC 7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 8:09pm
I am interested in you project to I have a 7060 pulling tractor and I was wondering if the high crops had a faster ring and pinion. Or some other way to speed it up. I was assuming the high crop final drive would be slower but I don't know and have not been able to find that information
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 8:33pm
As for available I know of two so far. The issue is getting a non running 12000 lb. tractor with flat tires on a trailer!
AGCO Parts Books research could possibly answer your question on ratios.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 8:57pm
I forgot about lift arms, gotta dig into that. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 9:03pm
if you can, take the tires off, the rims will roll easier than when the flat tires are still on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 8:49am
We have both 7000 and 8000 high crops. The lift arms will reach the ground with no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 9:17am
Thanks Dale.
This page was generated in 0.135 seconds.
