Having custom drapers made? |
| Author | ||
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8461 |
Topic: Having custom drapers made?Posted: 29 Aug 2016 at 6:50pm |
I've heard of a lot of guys saving money on All-Crop drapers by having them custom made by Amish/tent makers/sail makers, etc.
My questions are: For the slats, do you just cut wooden slats and have them riveted on? What do you use for the two attaching slats with all the holes and the tiny machine screws? What do you make those out of? Thanks
| Sponsored Links | ||
Carl(NWWI)
Posted: 29 Aug 2016 at 9:55pm |
Why not pay extra for the rubber ones that last longer?
Lonn
Posted: 29 Aug 2016 at 10:10pm |
They'll last a long time if you shed the machine during harvest time at nights, so dew doesn't set in on the canvas. Also, always take the drapers off at the end of the season and store them in a dry rodent free area. That includes on a shedded machine. The areas of the canvas that are in contact with any metal will deteriorate even sitting in a shed because of humidity.
Wink I am a Russian Bot |
CrestonM
Posted: 29 Aug 2016 at 10:25pm |
I always take mine off when I'm not using them. Plus, taking them off lets you clean out any straw that gets inside and wraps around the rollers.
TomYaz
Posted: 30 Aug 2016 at 4:07am |
Well I have a few of those metal slats left,(riveting them is your problem) and I have the attaching slats with the hardware. Or as said, buy the superior rubber version. Edited by TomYaz - 30 Aug 2016 at 4:08am |
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 30 Aug 2016 at 4:21am |
what? Creston....them blue tarps didn't work for ya?
Lonn
Posted: 30 Aug 2016 at 6:49am |
Stand on top with a long pitch fork. Problem solved.
orangereborn
Posted: 01 Sep 2016 at 6:11pm |
combinechris
Joined: 20 Jul 2015 Location: wittenberg,Wi. Points: 424 |
Posted: 01 Sep 2016 at 6:24pm |
I have no problems putting the old slats back on when I have the Amish make mine. The metal covered rubber slats requires 4 rivets and the rest is staples between rivets. It's best to let the dew on your canvases after the days harvest and after the tension is released from them since in the morning as the dew dries off of them it shrinks them . i
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
CrestonM
Posted: 01 Sep 2016 at 8:58pm |
Yes.
CrestonM
Posted: 01 Sep 2016 at 8:59pm |
But the problem is I don't have old slats to put on. I'm thinking about having an upper draper made so I'll have a spare, in case I need one in the field. I like to have extras of all that sort of thing so if something happens, we can get back up and going ASAP.
combinechris
Posted: 01 Sep 2016 at 9:44pm |
Amish can make and put slats on for you too if needed
CrestonM
Posted: 01 Sep 2016 at 9:50pm |
But the attaching slats are my concern. Wonder what to make those out of?
combinechris
Posted: 02 Sep 2016 at 8:08am |
Rivets and staples
shameless (ne)
Posted: 02 Sep 2016 at 9:46am |
Creston....dad had some made by a welding shop when he needed new ones on his. they used a small square steel tubing they had, cut to length and drilled holes where needed in them. was a lot cheaper at the time than buying from A/C.
he used small bolts with washers to re-attatch as he didn't have a rivet tool. after putting the bolts in and tightening them he ground off the excess sticking out. out lasted him! rivet tools are pretty cheap, but get a good one.
CrestonM
Posted: 02 Sep 2016 at 1:26pm |
I understand what you guys are saying, but I don't think I'm wording my question right. I understand how to attach the "regular" slats to the canvas, but the slat at the very end hat consists of two strips of metal that has a bunch of holes with the little machine screws through it. (The slat that the flaps pull through). What could I make those two pieces out of?
Edited by CrestonM - 02 Sep 2016 at 1:26pm |
