Allis Mdl G
Brad W Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad W Wi Quote  Post ReplyReply Direct Link To This Post Topic: Allis Mdl G
    Posted: 11 Jan 2017 at 3:54pm
Wondering if anyone out there knows if A/C made a snow blade for
the mdl G? I've been using one on my G the last 2 winters. It sure looks factory made and the color is right. No data plate or any kind of ID on it that I could find.It's a flat blade with holes and bolts for putting some pitch on it. It sits out front of the tractor. I made up some tire chains for it and I'm happy with the job it does. It does have some limitations though. Spun off 2 axels last winter, but even I learned something.
Brad W Wi
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 5:23pm
The G implement book I have on line in a couple pieces doesn't show a blade, but parts of several implements including the hand lift used by several would carry a blade with mostly Allis G parts. Then these manual scans could be old enough and a blade a newer product.
http://www.geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%201.pdf
http://www.geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%202.pdf
Gerald J.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 7:58pm
Brad, I've never seen or heard anything of a "factory" blade for the G, but I have seen numerous "home made" ones both mid-mount and out front.
Here's a couple of shots of the G factory employees scraping a rare Alabama snow in Gadsden with one they put together there.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 9:02pm
Looks like a blade mounted on a cultivator frame.
Gerald J.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 9:06pm
I thought about doing that with my G. Just making a blade to mount on the cultivator frame.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 9:42pm
Look at 8:00 on this video.
G video
The mechanic always wins.
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 8:40am
Good morning. Check this out. As with most things, it only takes time and money.     Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 10:01am
Whew! That looks hard to steer, with all that weight!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 10:20am
Pic of one of my G's
ALLIS EXPRESS!
This year:
