WD- Play in the hydraulics control lever
john0030 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john0030 Quote  Post ReplyReply Direct Link To This Post Topic: WD- Play in the hydraulics control lever
    Posted: 07 Jan 2017 at 8:09pm
My hydraulics always seemed to have a mind of their own. At first I was adjusting the flow regulator so that the hydraulics would adjust only slightly, but doing this was a real pain. Then I noticed the hydraulics control lever at the steering wheel was moving up on its own. Curious if anyone knows the fix for this? Currently I’m using an orange spring clamp which is perfect for now (no more dismounting and adjusting the flow regulator and control lever then hopping back on).
Edited by john0030 - 07 Jan 2017 at 8:11pm
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:42pm
   Had the same exact problem, replaced the friction block.......problem solved.       Duane
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:50pm
Make sure spring is not broken that holds tension on block.    MACK
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:07pm
Try the block first and if that don't do it replace the spring
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:16pm
Replaced blocks and springs on mine last week. Along with a new steering wheel, steering shaft, renewed throttle quadrant and lower steering support. Also had both control rods built up and turned down.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 10:03pm
Here's what you need, look in your tool-box, one came in all WD45 tool-boxes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john0030 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 10:24pm
THANKS!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 9:10am
John,
I agree replacing worn friction blocks and the springs can help assuming they are worn and or weak? Don OK I have never seen one of the clamps you show? And I don't remember one in the tool boxes on Dad's 45's!:) Picture on the tractor? I assume this is a stop for the quadrant handle???
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 10:25am
I have never seen one of those either.
I have not happened to see reference to it in the operator's manual either.
It is called" STOP ASS'Y., adjusting, hyd. pump lever".
It is shown on page 266 of my parts manual under "Tools and Miscellaneous".
It is also shown on page 276 attached to the quadrant under the heading "Hydraulic Pump Hand Control".
In that illustration, it is clamped on the quadrant below the lever which would indicate to me it is designed to limit how far the lever can be lowered rather than to hold the lever down.
Nevertheless, it sure looks like it could be used for holding the lever down as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john0030 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 10:45am
Quick question, according to the diagram in the owners manual, it would almost appear there should be a second spring somewhere at the bottom between the end of the lever shaft and the lever shaft arm. is this the case or just one spring up by the quadrant?
Edited by john0030 - 08 Jan 2017 at 11:03am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 10:47am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 1:56pm
don can  you toss one of those in my two tool box's it seems like the slightest movement on the quadrant on my wd45 makes it creep up or down but all of my linkages need tho be re biult to take up all the play
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 2:19pm
The part diagram shows the order it goes together spring goes on bottom because that's where it's put on shaft to slide it up towards quadrant with the retainer and pin
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 2:41pm
Don, finding those is like finding hens teeth! I've scavenged a4 or 5 over the years and it's always fun when you do find one, but hard to do!
Post Options Post Options   Thanks (0) Thanks(0)   Quote john0030 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 3:00pm
Thank you all!
This page was generated in 0.112 seconds.
