7000 Radiator Foam Puzzle, need help
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Radiator Foam Puzzle, need help
    Posted: 31 Mar 2014 at 4:44pm
Can anyone tell me how these pieces go around the radiator?  I have a couple that I am pretty confident about, but I don't want to glue anything until I know for sure.
Thanks,
Hurst
1979 Allis Chalmers 7000
5800 Hours
Orangie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangie Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 5:11pm
Hurst, I have done these on our tractors. #2 goes on the sides of the radiator, #3 I think goes on the front bottom of the radiator,#1 goes over the top of the radiator,#7 goes on the front bottom to seal the side hoods,#4 goes around the air intake tube, but I have never really got that one to fit very good. Good luck! Is that an AGCO kit or is their an aftermarket? AGCO ones are kinda pricey.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 6:20pm
This is the kit from HyCapacity.  It was about $70 vs $100 for the AGCO kit.  I'll have to give the jigsaw puzzle a shot again tomorrow :)
Hurst
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 7:40pm
I was just looking at it again after Orangie's advice, and here is what I have figured out:
1 seems like it should go on the top, but fits a little weird.
2 goes on the side of the radiator
3 I am still trying to figure it out.  I have the hydraulic cooler lines coming up from under the radiator, so I think that is where one of the 6's goes? But maybe not?
4 Over the air pipe
5 Have no clue, they are pretty good size blocks, about 4x4x6
6 I think one of these goes on the bottom of the radiator?  The slits line up with the hydraulic lines
7 I am not 100% sure, but the drawing that came with the foam kit does say "foam here" pointing up near the cab where the thin part of the side panels go?  If not there, they are the perfect length to fit between the two bolts where the radiator mounts to the rubber isolators (They are only about 3/8" thick, which is kind of hard to tell from the picture)
8 are the two bottom strips that run along the edge under the air filter
Hurst
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangie Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 8:13pm
Hurst, I stand corrected on those thin strips, I think you are supposed to squeeze them in between the radiator and radiator support brackets!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangie Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 8:20pm
Hurst, I didn't slide your picture over to see #8 but I think that is what goes in the front bottom of the radiator, and #1 & #3 just use which ever one fits the best on the top of the radiator for your 7000, which one you don't use is extra.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 9:44pm
made my own on the last replacement on my 7010. just hafta remember..the air needs to go thru the radiator, not around it! used just regular ole foam rubber outta a couch cushion, cuts real easy with an electric knife!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 9:57pm
Ok, it makes more sense if there are extra pieces in the kit.  I was wondering that because it seems like a little too much foam for what little voids there are around the radiator
Hurst
5800 Hours
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2014 at 6:06am
If AGCO was $100 then they have come down. I believe a few years ago they were at about $140 when I checked last. I saw the aftermarket ones just recently.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2014 at 8:15am
I did the foam in our 7010 this past week, but went to Wal Mart and got the 2x2 window air conditioner foam in strips. Isn't the same quality of foam, but was less than $10 for enough foam. Had to get a tube of 3-m glue also.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2014 at 8:40am
Pool foam float knoodles. Shave flat the side being glued to radiator.
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 11:06am
This is an old post, but a good one, since I too am trying to put this puzzle together.
Anyone ever figure where the #5 blocks go?
Thanks,
Roscoe.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 12:45pm
Front lower corners of the orange grille.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 1:10pm
#5....I think go up inside up under the console. above where the clutch cable goes. hafta take the bottom steel plate off above the pedals to put them in there. it's a sound deffening thing.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 4:00pm
Front lower corners of grill like Lynn said. I put regular egg crate foam and insulation up around and under the console. But something like #5 was in there where Shameless said originally.
Wink
I am a Russian Bot
This page was generated in 0.114 seconds.
