i am now a sickle expert
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Topic: i am now a sickle expert
    Posted: 27 Sep 2015 at 9:00pm
Well at least i feel like one! Spent 8 hours today fixing my gleaner F sickle. Replaced the head as it was broke in half. Welded a gaurd that had cracked. And swapped in some very worn wear plates for some less worn ones i had that came with the combine. Oh also about 10 sections got replaced and i file sharpened some others. Oh the best part! Forgot to order the half section that goes on the end and was missing so i cut a regular one in half! Works great now!    It was badley in need of tlc
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2015 at 10:28pm
did you re-rivet or bolt it back?
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2015 at 11:56pm
you are not a sickle expert till you get to mess with rivets with a hammer, chisel, and punch.
I can do it, but for the sake of the cutterbar and my sanity, its best I didn't. :D
My old man can do it quick, I am impressed and POed at the same time. Consequently, he doesn't see the problem with rivets and won't pony up for the bolt on... :)
Edited by GM Guy - 27 Sep 2015 at 11:56pm
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2015 at 3:12am
I have a rivet tool and still hated doing it that way. easy to change over to bolts!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2015 at 8:46am
I ground out rivets and replaced with bolts. This cutter bar is about half and half. The wear plates and hold downs were all about 1/4" from the sickle so it was moving around too much. Thats why the head broke. I really need about 12 more sections done and all new wear plates with a few gaurds but had to get the beans done. It really sucks not having a dealer close by
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2015 at 8:54am
Really not a bad job its just when your trying to beat the rain and at the same time do your best with what you have it gets a little crazy. If i had a nice concrete floor shop and a rolling stool id be set!
mintenfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2015 at 11:57am
I grind the rivets off and then put the impact on the tool for the new ones
