CA parts help |
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5092 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jun 2015 at 9:10pm |
I'm looking for the pad that goes in the center of the radiator on the bottom. It goes between the fins and the surround/case. Its a fiber type material and I was wandering where to get one or what to use in its place. I've found the rubber washers that go on the bolts but can't seem to find the fiber piece. Any ideas?
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11994 |
We have the fuel tank welting. Not sure if its what your referring to though. Just a thought..
This is like a block sort of. It's about 1/2 or maybe 5/8 thick and 2 inches or so long. I don't think it's the same material as the fuel tank Welton but that might work.
I'll see if I can get a picture of it this afternoon and maybe that will help Edited by thendrix - 22 Jun 2015 at 7:59am |
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6468 |
Tyler, sounds like what you are looking for is a phenolic block. If you can't find one up in your area let me know and I will check around and see what I can find.
Ah! Phenolic! We use quite a but of phenolic at work so I should be able to come up with something. Thanks hubert. I guess I should have taken it out and then I would've known but I was afraid to take it out and break then not be able to find one
