pulling chassis pic
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Topic: pulling chassis pic
    Posted: 04 Dec 2011 at 8:01pm
here is a pic of our pulling chassis even if it is off color.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 8:04pm
i been working on  a set of billet alumnium heads and getting the engine adapted to the clutch can getting the spaceing right etc.    also got to make a new starter setup and pump drives off the crank nose as the block needs to get cut off where the original starter is in order to fit in the frame
Edited by wi50 - 04 Dec 2011 at 8:08pm
lussetto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lussetto Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 8:20pm
Looks nice, light super??
Greg
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 8:43pm
This may be a dumb question, but when you get to that point is there even a tractor part left on there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lussetto Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 10:17pm
Engine and hoods only, but with the kind of hp they are making in the big classes it's the only way they should be.
Greg
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 10:37pm
Greg
   Depending on the class you dont even have to use an AG engine or the same brand as the sheetmetal. Heck, even the "sheetmetal" don't come from a tractor on most pullers anymore ! And I disagree, this is not how it should be. Most of "Tractor Pulling" has turned in to drag racing with big tires !
Edited by Rfdeere - 04 Dec 2011 at 10:40pm
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote lussetto Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 10:50pm
NTPA is the only one I know of allowing 4wd (still has to be an ag engine) and crossbreeding.  I don't agree with either.  However running 2500-4000 hp through factory housings is not really safe.  Factory chassis are just fine for the Limited Pros on down.
Greg
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 10:57pm
bounce a cast tractor chassis around and see how much it will take or twist some axils comeing off the line and see how bad you want to climb back in.  i want to have my fun and i want to see how much power i can find but most importantly i want to put my little boy to bed at night.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 11:03pm
   OK, But you are not building a "tractor" puller anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lussetto Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 11:18pm
In your opinion, not mine.  The components are about safety and realiability.  At the end of the day, I will still be rooting for the IHs and ACs because of what is making the wheels spin.
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 11:26pm
Greg
   Most of he engines in "tractors" like the one above are not really an AC, IH, JD, etc. They are custom machined blocks, crankshafts, pistons, camshafts, etc. None of this stuff is getting pulled out of a junkyard or bought at your local implement dealer.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 11:50pm
i like old tractors too.  here is an ols picture in my file of my wc.  it uses some ac parts some perkins leroi deere and a lot of parts i built
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 12:06am
here is one of the intake and exhaust.  i had to make a water manifold to draw water oo at each exhaust port.  i cut access holes near the intake ports and filled the head around the intake runners and valve bowls to cut new intake ports in.
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 6:24am
Wi50 - is your transmission an Easton or Fuller?  It looks like one I have seen in a semi truck.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 7:43am
I agree, and my hat's off to you for doing it right. Once or twice a year I happen to be somewhere when a brush pull is going on and those guys dropping modern pulling engines in an old 1066 or 4430 with thier head for a rollbar are short on,,, something.
However I do agree that pulling has developed into tractor dragracing and it's because of the way the drop pan sleds work. Nothing, nothing, nothing and then whamm. Speed is the only thing that wins,,, I am rambling now, sorry I dont have a stick in the fire.
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 7:45am
regardless of what anyone says (tractor or not a tractor) it dont matter!!!! cause you are doing what you love to do as safe as you possibly can!!! the way this post started it wasnt asked it this is still considered a tractor or if its right or wrong. simply showing us a hobby or project that someone is proud of doing. and i thank you for posting the pics. not everyone gets to see all that goes into these high horsepower machines.
allis6080
6060 s\n 5016
1947 JD B
Iowa_Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iowa_Allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2011 at 8:31am
Wi50 thanks for the pic.  I'm envious of you guys that can do that kind of fab work.
As far as the other debate going on here, in Iowa they still have the farm stock, super farm, etc classes for everyone that doesn't want to build a rig like this and who wants to pull a tractor with original parts.  Don't they also have those classes elsewhere?
