Wd45 questions |
Allis-chalmers wd45 ![]() Orange Level ![]() Joined: 11 Apr 2012 Location: Newton, Nj Points: 1917 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Apr 2012 at 8:09pm |
Hi, I just got a wd45 and the spinout rims are stuck on it I was wondering what the best way to un lock them would be? Any suggestions thanks
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
If PB Blaster and a few hard raps on the end of the eccentric nut do'nt loosten them. the best way is take them off the tractor lay flat on the ground. take out the 8 bolts holding the locks to the center and pound the center out. once it falls apart clean and loosten all the parts. antisieze the eccentrics and put back together.
Thanks for the tip will definitely have to give it a try!!
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
you dont need to remove the wheel.just start at yhe top eccentric,remove it,free it up,reinstall and move to the next one till all are free....
That also sounds good I will try that first thank you!
ALLISMAN32 ![]() Bronze Level ![]() ![]() Joined: 13 Mar 2011 Location: Hillsboro, IN Points: 199 |
Usually have to end up doing the steps that Dakota Dave described. With the eccentrics off the rim center you can lock them in a vice and hammer on the cam bolt with a impact back and forth until they loosen up. Experience has shown the bigger the impact the better too. Seen some that the 3/4 drive really struggled to loosen but persistence will pay off in the end.
Alright I'll just have to try it all . I've already snapped the drive off my breaker bar . But thank you for the help!
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Sometimes driving them back and forth with a really big hammer helps to loosen them so the impact wrench will turn them.
