D-17 cam
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: D-17 cam
    Posted: 16 Aug 2010 at 3:54pm
Is Barney taylor the best one to get a cam from, do they put out good power. Mine needs a little help. lol
Thanks Carl
ORANGE FARM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ORANGE FARM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 4:03pm
berry cam service lester prairie mn.
good people to work with
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 10:26am
alright thanks. Does anyone know how to find compression ratio. i have 4.125 flat top pistons. stock stroke
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 10:55am
We put one in a WD puller had to change gear on oil pump though, must increase speed of pump a little but no difference felt in power. I think the only cam that is better is 175 cam.
B212,716,two 314H's,WC,WD,D19,190XT
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 11:42am
measure how far down the piston is at tdc.  then use a compression calculator . to find out what it is. I think barneys camshaft is a little better suited for pulling than a 175 cam my opinion is based on talking with him and having one that was ground by the same grinder once.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 12:32pm
I thought he was just talking about a regular D17 cam. ya,if it is reground for pulling definetly better.Ideal would be to have ground for your setup,rpm,etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 5:11pm
sorry, should have mentioned it was for pulling. will this help me a bit, or do i need more work done?
