D17 power adjust wheel
D17Diesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17Diesel Quote  Post ReplyReply Direct Link To This Post Topic: D17 power adjust wheel
    Posted: 11 Apr 2012 at 8:25pm
Hey guys just wondering what the best way is too put the wheel and locks back together in the rim.
Thanks Dennis
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 9:05pm
I usually set the wheel in place with the tractor low enough to allow you to insert a lock at 10 o'clock and 2 o'clock. once they are in, I jack up the tractor and do the bottom ones. With the wheel set back, just set them on the rail and slide them in. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17Diesel Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 7:57am
Hey thanks for the reply, so your saying its easier to put the wheel back on the tractor then put the locks on the rail? i have everything all off the tractor right now and i can get 2 3 of the locks on but cant get the 4th one in place. Thanks again
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:09am
I lean the outer rim/(and tire) against the wall (outsside towards me) with one rail on the bottom, slide the bottom eccentric on the rail, set the center on it and install the 2 bolts holding it to the center finger tite....then slide the the 2 sides in and install the holding bolts and finish with the top. Keep the center towards the outside of the rail. Tighten all bolts and install the completed rim/(and tire) assy on the axle. Adjust the wheel width, instal the locks and tighten the eccentrics. Can be done by yourself; however a helper makes it much easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17Diesel Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:00pm
thanks for the reply but i still cant seem to get this thing together i cant get 2 maybe 3 but the 4th one wont go in .
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 6:25am
Are the 3 that you have installed in the Release / Loose  CCW position ?
4th one should just slide along the rail and in to position.
   Gary
This page was generated in 0.049 seconds.
