Side board chains connector
David Grubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Topic: Side board chains connector
    Posted: 06 Jun 2012 at 3:51pm
I made a 3 sided box type unit to use with my snap coupler carrier. The idea is for the grandsons to ride in there with their mother & Gammy and toss candy to the folks along a parade route (still legal so far). I want to put a chain across the rear opening like the ones used to keep the sides of wagon beds and grain truck sides from breaking over when loaded. I am looking for that weird bent up piece of steel rod stock that joined the left and right chains together in the middle. It would pass through a link and you folded it over and it would stay in place due to an over center type loading.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 4:23pm
Dave - I know what you mean.  My Dad used those on our grain wagon.  Had a rod in front and chains with those "buckles" in the middle and back.  Haven't seen them in years.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Neil MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neil  MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 6:08pm
Dave,
They use a similar connector on tire chains.
Check out:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neil  MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 6:28pm
Dave,
Here is a picture of an original from a Minnesota barge wagon if your interested in making one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 9:32am
Neil that's the weird little thing. I'll try to bend one up. That offset in the bends is really touchy as to weather the chains will stay together or not.
Dave
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 9:37am
David, Don't forget to add the extra ring that the end of the rod slips under to prevent it from coming unhooked.
