D-17 water pump question
lucky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lucky Quote  Post ReplyReply Direct Link To This Post Topic: D-17 water pump question
    Posted: 20 May 2012 at 9:11pm
Noticed a leak on the front of the pump and grabbed the fan / pulley and it wobbles.
Are they rebuildable?  It still runs cool and doesn't leak too bad but needs fixed.  Noticed on ebay they were upwards of 100 bucks.  I don't mind repairing it if possible, but will more than likely involve a bearing of some sort??
Any feeback on what i'm up against here is appreciated.
Thanks,  Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 9:15pm
Several vendors on here re-build them or can sell a rebuild kit. I am sure 1 of them will chime in .Steve in NJ comes to mind
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 9:33pm
You will have a hard time finding a rebuild kit.  New is a lot easier, and I'll bet cheaper in the end.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote lucky Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 9:44pm
JimD
I'm betting your'e right on that.    The way it wobbles the bearing probably did enough damage to the race for me to handle it.     That wouldn't mess up the core value would it?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 10:47pm
I don't know of any vendor that wants the core anyhow, but I may be wrong.
Still in use:
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2012 at 7:08am
When the one on my WD45 started leaking I went with a new unit. Sometimes they will give you trouble when trying to rebuild them yourself...clearances have to be just right.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2012 at 7:40am
Rebuilding a waterpump is a risky affair for most mechanics. Have had better luck with new/re-man ones. Jim D (OK Tractor), Tony C (Tonys Tractors), Steve in NJ, and Sandy Lake Implement all are great folks and can get you a good replacement.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2012 at 10:37am
Usually the impellers are so corroded that they don't survive removal no matter how careful you are.
This page was generated in 0.039 seconds.
