CA Question
houchens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Topic: CA Question
    Posted: 16 May 2012 at 10:38pm
How many plows will a CA pull? Also, what do you all think is best? A wide front or narrow front on a CA (for cultivating)? I'd assume the narrow front, but havent had much experience with a CA.
8050 200 7010 185x2 D17-IV D15IIx2 D14 WD45 Deutz Allis 6260 Gleaner Kx2 Gleaner K2 Diesel 2300 discx2 600 and 333 planters 2 AC wagons several AC plows/chisels Rotobalerx2 Other Misc AC Equipment
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 5:41am
I have only ever seen one plow on a CA at a time, and it was usually a two furrow plow.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 6:10am
The CA was sold as a 2 plow tractor. 2-14's in most ground although Dennis  on here has shown it will pull 3-14's in his ground.
 I think the narrow front would be much easier if you are going to plow and cultivate. You never have to adjust the front wheel spacing and cultivating 2 rows at a time makes for a pretty sharp turn on the ends which I believe would be easier with the narrow front.
 Some seem to think the wide front is a big advantage when working hillsides but the front pivots and does very little to stabilize the tractor on a side hill till the front axle hits the stop. By then, you are tipping too far to be safe with any tractor.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 10:49am
A good condition CA will handle a 2X14 plow nicely in most soils. Weights on rear tires (wheel weights or fluid in tires) are a real plus to minimize spinning...and front weights are a plus in keeping the front tires on the ground when lifting the plow. The narrow front turns tighter; the wide front is more stable on slopes
