85 912H with K301 Kohler suddenly running terrible |
kenora ![]() Bronze Level ![]() ![]() Joined: 26 Apr 2014 Location: CYQK Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 28 May 2015 at 3:27pm |
I have had the tractor for about 20 years, it has always run well.
I ran it this winter using the snow-blower about 20 hours and was cutting grass for about 2 hours this weekend (at full throttle the grass was wet and high)... when suddenly it began back firing through the carb and won't tolerate any load at all. I limped back to the garage and thinking I got a bit of garbage in the carb took it apart and cleaned it. I reset the idle and high speed screws at 2 turns out each but there was no improvement. The fuel is new, the plug is new.... When started from cold it idles nicely for about thirty seconds and then starts to burp and back fire, it can't take the load of moving without bucking and sounding awful. I have done what I can....any ideas? Thanks |
Jim Hancock ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
When was the last time that you changed the points and condensor?
Or, the flywheel key is sheared ever so slightly to throw the timing off. That's the first thing that comes to my mind. Checking those things. HTH. Jim
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11986 |
Hmmmmm.... fuel is new. Possibly a bad batch of fuel sounds like to me to all of a sudden run lousy. I would drain the tank, and add fuel from another can or source and then give it a whirl again. Make sure you drain the carburetor. Couldn't hurt to add a dash of dry gas to it also just in case you got the bottom of some gas stations tanks... HTH
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3869 |
replace the points and condesor change out the gas
Thanks for the advise...the gas is changed already and I'll hunt down points and condenser....I priced the coil locally and it was $368.00 plus tax...OMG...I never priced the points and condenser cause I was on the floor!!!
Found them on EBay for $37.00 Cdn shipped to my door...the local dealer wanted $60 plus tax...
wrong info there points4715003s napa store 12.00$ condensor230722 6.00% napa coil231281napa30.00$ hope this help all oem #s cross to napa parts
