Rusty redneck B flywheel issue...
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Topic: Rusty redneck B flywheel issue...
    Posted: 28 May 2025 at 7:48am
Well folks, during the forum outage my chino-carb arrived (Marvel Schebler TSX replica listed for Farmall) so I modified the linkage to suit the Allis & installed/tuned that.
After getting the tractor running well (better than she's ever run as a matter of fact, the chinky "Gxywady" brand carb works just great) I did notice an ominous rumbling/grinding sound that appeared to emanate from the bottom end. Initially thought this was the loose main bearings coming back to haunt me although oil pressure remained good still.
Anyway, moved the tractor over to the car to inflate the tires and noticed the noise quietened down as I pressed the clutch, and then it got louder quickly & lost drive. Before I could shut the engine down it changed note and the idle went super lumpy like it had a big cam. Touching the throttle out of curiosity and she revved like a sport bike!
Shut her down and noted the flywheel continued to rotate in the bellhousing so I guess either the flywheel came loose or the crank broke Dead
Hoping it is just the flywheel bolts backed out & not done too much damage to the crank, else it's looking like engine swap time for the old girl. Strange thing is, I never had the flywheel or clutch off the engine & it all appeared to be fully installed when I bought it. Guess that just goes to show you should never trust "the last guy's work"!
Will let you know what I find when I get her split, fingers crossed not too severe!
Stuck Farmer
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 11:22am
Yikes! Cry
Post Options Post Options   Thanks (1) Thanks(1)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 12:24pm
Yikes indeed, I suppose its really my own fault for assuming the flywheel hadn't been messed with because the clutch was already installed. Especially given the history of the engine.
Anyway got the tractor split now and it's plainly obvious the flywheel was only ever on with two bolts (who knows how tight they were either?)
Will add photos later when we get home as on phone currently, but I'm just guessing cobwebs in the bolt holes ain't a good sign? Lol. Fortunately the crank seems ok and only one bolt is broken below the surface, other one is broken flush and threads look fine in the other pair so it's looking hopeful for a fairly quick n easy repair with just 4 new bolts and lock washers.
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 12:44pm
sounds like minimal damage with the flywheel.. good luck with repairs.. glad the Chink carburetor worked out for you !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 10:32am
Yeah, got pretty lucky really. With luck should be photos of the minor carnage now, along with spider webs where bolts ought have been!
Looking at the broken bolts I'm going to say they were not particularly tight, looks like one broke from fatigue and the second one began working it's way loose (there's my noise!) before also shearing.
Just a tiny scar on the crank that needs dressing with a file, and extract the broken bits of bolt & be back in business.
Stuck Farmer
Allis dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 1:06pm
That was lucky. Glad it wasn't running wide open.
Last guy must not have known or cared much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 2:47pm
Agreed, back when I bought the tractor as a pile of bits the last owner had given up after fitting fresh big end bearings & the crank was tight. Turns out it had been assembled with no shims.
Not knocking the previous owner mind, this was a stalled/failed restoration of an American tractor in the UK well before the internet was a thing (probably very early 1980's) so information was probably quite hard to come by at the time. The flywheel situation I feel is on myself for not checking behind the clutch before installing the engine, a lesson learned Smile
Stuck Farmer
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 8:34pm
Glad you dodged that bullet my friend Smile
40 years ago when I overhauled my first Model C all I had was an I&T manual (still have it). Nowadays we can look up most anything online.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 12:50pm
I just have the I&T manual as a PDF, how things have changed (mostly for the better).
One thing the manual doesn't show is what bolts I should be using, the remains appear to be 7/16 fine thread at 1 3/4" length excluding the head. Would certainly appreciate if anyone knows for sure though.
Stuck Farmer
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 2:06pm
Since I have not yet installed the flywheel on my B-125 engine I have the bolts right here at hand.
Mine are 7/16" NF thread and 1-1/8" long (excluding the head). There is an un-threaded shank of 3/8" next to the head. The overall length including the head is a smidge over 1-7/16".
There are lock washers on each bolt.
The head of each bolt has raised letters in this pattern:
   FC
    B
I have no clue what those mean.
Post Options Post Options   Thanks (1) Thanks(1)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 4:21pm
Thank you very much sir, that is much appreciated.
Stuck Farmer
