price on pin and bushing turn
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: price on pin and bushing turn
    Posted: 12 Sep 2012 at 5:24pm
i got a price for a turn on my hd5 pins and bushings. $350.00 per side plus bolts. does this seem reasonable or should i keep shopping around. they are 33 links and dry. i tried to work a deal to remove the pads and save money but he said it would be the same price. $20.00 for a master pin also. he said john deere 350 was same diameter but a little longer and could be cut. anyone have tracks turned lately?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 5:30pm
sounds cheap to me.  dad priced pins and bushings turned on Hd10 track a couple years ago and it was $1500 per side and we had to remove pads
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 6:58pm
The track bolts are extra right? When I bought track bolts they cost $175 per side. That is a lot of labor for $350 per side. Go for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 7:11pm
he said a bolt and nut was $.60 each whic i thought was cheap. i can see larger tracks being more as they naturally are longer and take more force to push apart and together. was about $80.00 for 1 side of bolts as they only have to remove one side of bolts for the turn. thanks for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 7:48pm
When they turn the pins and bushings they only remove one set of bolts and leave the pad on the other link , no reason to remove both sides.
 Last set I had done was a few years back and ran $450 for labor , about the same price for bolts as you state. Then I had a large supply of larger bolts so I just traded with shop.
