woodlot tractors |
John Ontario
Bronze Level Joined: 22 Mar 2010 Location: Ontario Points: 10 |
Posted: 09 Jan 2011 at 6:35am |
I bought a set of chains for my 45 and have been pulling some firewood out of the woodlot the last few days. Great way to spend a day. I was wondering what tractors you guys out there use as a woodlot tractor?
Rick
Orange Level Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3641 |
My brother and I use D17's and D19's to skid logs with,but have used a WD45 to skid fire wood logs with (the rest of the tree actually after the log was taken) ,before we started using the bigger tractors. The D17 and the WD45 are pretty easy on gas,but the D19 uses a lot more,but then you've got more horses there and also two extra cylinders. They work real good for us. Rick
B26240
Orange Level Joined: 21 Nov 2009 Location: mn Points: 3860 |
Farmall H off color unit so Ill be less tempted to start fixin and end up with a useless pet.
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18727 |
I'm with you, I use my 45. Good for pulling smaller stumps too.
Tim in arkansas
Silver Level Joined: 11 Sep 2009 Location: Charleston AR Points: 191 |
Back in the day Dad and I would use the WD then we used a Massy Fergason 50 and we also used my model B for the small stuff pulled up to the house and cut it up there then used the log spiter
Allis Chalmers fan from Arkansas
Denis in MI
Orange Level Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
I use a old Cletrac that I bought at a auction just to stop a scrap man from buying it.
heres a picture
It is wore out but works, the previous owner replaced the original engine with a flat head six cylinder from a chrysler. The only problem with it is the engine turns so fast to build power you cannot push anything but it will pull the world.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
D17 owner
Orange Level Joined: 03 Jul 2010 Location: ladysmith Wi Points: 225 |
I use my belarus 400. I dont care if I scratch it up I bought it pre dented and cant hurt the value of it it ant worth nothing!
Brian G. NY
Orange Level Joined: 12 Sep 2009 Location: 12194 Points: 2198 |
I use my WD. I leave the back blade on and sometimes use it to lift the butt ends a bit to make 'em pull better and keep 'em out of the mud. These are some logs (not firewood) I skidded out of my woods to have sawed. The guy with the trailer didn't think I could load that 14' log for him. It was a Hemlock so no problem; if it had been red oak.....well....maybe not. LOL
John Ontario
Brian, Those are some nice sized logs. Your wd skidded them out without much problem? I have some oak saw logs that I have been thinking about dropping and pulling out but the price is way down here and they are only getting bigger where they are. I didn't know if my 45 would be able to handle them or not.
John
Rick
John...The WD45 will pull more than you think,but just make sure that you have plenty of weight on the front end,so it doesn't rare up on you. We use log hooks/tongs to lift the logs up on one end and skid them that way. We also spin the rear rims out all the way and they have fluid in them for traction. The main thing is to be safe...safety comes first! Rick
Brian G. NY
I have wheel weights, CaCl loaded tires, the rear blade with 4 suitcase weights on it and chains. All of these help when skidding logs. I have skidded oak logs as big as this with no problem.
The front end loader keeps the front end down when I climb some of the steep log roads on my place. I like the back plade on there as it will keep the WD from rearing back on me if a log catches a root.
The bucket comes in handy for moving rocks and such that come up in my way.
I have pushed over many trees up to 10" in dia with the FEL as well. The length with the FEL and the blade make it necessary for me to make a wide path where I need to turn around.
Jim Lindemood
Orange Level Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
Brian -- I'm impressed. I'm like the trailer guy and would have bet against it. Those are some pretty good sized logs.
