Harbor Freight Welding Rod. |
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8834 |
Posted: 18 Mar 2024 at 11:23pm |
If you have welded with Harbor Freight welding rods, please let us know how well it worked.
I usually weld with LaGrange, Eutectic, Lincoln, Hobart and other welding rods. Really like LaGrange and Hobart electrodes. Compared the welding rod prices at TSC and Harbor Freight. Harbor Freight was almost half the price of TSC.
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 1814 |
I don't, or won't skimp on electrodes. Too much at stake for me personally. Either Lincoln, or Hobart Bros. from a welding store only whether online or local. Same with wire and I still use both dependent upon location of repair.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21550 |
I've tried 'economy' rods in the past. waste of time and money. While I liked saving money, it was the waste of MY TIME that 'irked' me. My old AC buzz box is fussy, loves 7018AC rods.
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4415 |
I don't do a lot of welding anymore and EVERYTHING I do weld is stick welded (old timer that doesn't want to change). I do a little welding on old horse drawn equipment (mostly) for my Amish friends. I've used Harbor Freight rods some, with no problems.
I have also used Lincoln rods from Walmart (MUCH CHEAPER than the local welding supply stores).
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11399 |
One of these years when I’ve got nothing better to do and I think of it, I’m going to learn about welder DESIGN. I certainly get the general idea, but I wanna know intimate details! I’m probably never going to get around to it….and if I do I’ll probably be too electrically dumb to understand, but dang it!
Jay’s comment about his old buzz box being fussy. Guess mine is too! I’ve got a Miller M-180. I would guess dad bought it in the late 60’s, but I don’t know for sure. I had a big project that needed good welding. Based on Jay and others advice I bought some 7018 rod. I had brand new rod, kept warm and dry until the last possible instant before getting placed in the stinger. I ground a fresh shiny groove to weld into. Shined up the ground clamp and the metal I clamped it to. Also cleaned the cable clamp side of it. Preheated the work area and was ready to weld like a pro with this highly recommended 7018. I could NOT get an ARC to flow to save my life! Mmmtht mmmtht mmmtht….current up, current down, current up so far I should have blown electrons to the neighbors house….mmmmmtht! Switched to two different rods, welded like a dream. I don’t get it! Rod was bought from Tractor Supply. But so were the other two types. |
Codger
There is a difference in the flux coating on rods that are 7018, and 7018AC rated. I've never used 7018AC myself as have most always had DC power sources available. 6011 is a very good general purpose rod to learn with, but if using new steel then try 6013 as it's probably the easiest to establish and carry an arc with. However, 6013 is not a deep penetration rod so not very good for structural uses. It is also terrible with any rust or dirt present so use only on new, or very clean baseplate. 6011 is either AC, or DC rated and usually won't yield as pretty of a weld as 6013, but will sure dig into the baseplate. I still use 6010 and 7018 when the need arises, but mostly have gone to flux core and a suitcase feeder for outdoor work. In the shop, it's always wire feed. That Miller built all those years ago is better than a brand new one IMO. Once you learn to establish and carry an arc with an AC power supply, move to a DC power supply and you'll not go back very often unless welding aluminum.
Tbone95
It was AC rod. I really don’t know what the heck else I could have tried that day. I used both 6011 and 6013 that same day, easy peasy. I used 6011 for deep penetration, then covered it with 6013 to pretty it up some. The project turned out pretty good that day, given what it was!
I’d love to try a good DC welder. Like to find an old working one for cheap. Hard to justify a lot of money for one because I only weld a few hours a year really. |
Codger
In reality, 7018AC is a compromise to make the rod work on AC. 7018, (any variant) always forms an insulating ball on the end of the electrode when you let go of the arc making restarting extremely difficult at times. I have a rough piece of serrated steel plate I bang the end of the rod on to break this off. Even on new rod that is not fresh out of the can this is beneficial to do as the flux on the rods readily absorbs moisture causing the rod end to oxidize/rust. I don't use a lot of 7018 but the leftovers from a job are kept in a rod oven that maintains temperature so they stay good. Usually break open a new tin, (don't purchase plastic, or cardboard cased 7018) as it's moisture sealed and if any left over, it's kept in the rod oven for projects without much merit, or value.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77984 |
90% of my welding is done wit 3/32" 7018 on a Milled DC stick welder.. I have been a "well above average" welder for 30 years... I have been buying economy rod on e-bay for the past 10 years.. About $25- 30. for a 10 pound box.. as long as it MEETS THE SPEC i have had great luck... No problems......I buy a box every 4-5 months..... buying 2# boxes is not economical... The 1/8 inch rod is too big for many of my jobs, but i can use the 3/32 on them and also larger jobs..
Specification: AWS A 5.1-04 : E7018 SIZE : 3/32" x 12" length Weight : 10 lbs Welding Rod Material: Carbon Steel Welding Rod Type: Arc Welding Rod High Quality welding rod !!! Edited by steve(ill) - 19 Mar 2024 at 9:04am |
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 632 |
I have been a "well below average" welder for 50 years, so there! I have noticed that my Lincoln 225 Amp AC Buzz Box is a lot happier with Lincoln 7018 AC-RSP than it is with Hobart 7018 AC (non RSP). I dunno what the actual difference is, but it sure runs better for me. That said, I could not live without some nasty old 6011 rod around the homestead.
Edited by Les Kerf - 19 Mar 2024 at 10:49am |
Tbone95
All this sounds like such good advice. I left off the fact that I put a handful of that rod in the oven on warm for a couple hours before I used it. I tried everything I’ve ever heard of! Then you see Steve’s post right below, buying cheap rod in a plastic container Yeah. Sigh. Edited by Tbone95 - 19 Mar 2024 at 11:35am |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29655 |
My own are Union Carbide labeled and likely 70+ years aged, have been reliable performing same exact operations as taught by a Old Welder.
good clean spec rod sure helps... But a Quality DC machine and having a bunch of training / practice makes a BIG DIFFERENCE...... I can let my son try to weld with the same rod / same machine... and it looks like crap... so TRAINING is a big input.
Regardless Price, I buy my rods from my local Steel Supply yard, they purchase for Life and Viability as well less inclusions in a Good Weld, have issues on anything I want to do out of Safety or Strength of Cheap Rods.
Edited by DMiller - 19 Mar 2024 at 1:10pm |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41217 |
changed over to 6011 rather than 6013 , and 7018 for other work . have used 7024 for welding rousers onto dozer track
Used a Miller 180 AC since 1964 and still have it but gave up and bought a Pow - Con unit with wire feed around 1980 or so . Can stick weld DC either polarity , wire feed with .035 wire and Argon /25% CO2 as well as straight Argon . Wire feed 70S wire and 304 SS wire . Cast iron welding Allstate #8 for most or butter material with SS rod and then 7018 filler Do some TIG work also but Pow-Con was scratch start and hard on tungsten . 2003 when I closed down company I was millwright at I bought some shop equipment , lathe, vertical mill , 60" band saw , power hacksaw (band saw) but best deal was the Miller 304 welder with water cooled TIG and high frequency and foot control . Son has used it for the last 20 years making his skid loaded attachments and untold number of rolls of wire have been burned through it . He bought 3 more Miller 304 units from a fabricator who went out of business . He also has 2 Thermo Arc units - they bought out Pow-Con which later was bought by Miller |
back to the original Question about Harbor Freight.. I checked their site and dont see anything i would buy... MOST of their 6011- 6013 rod comes in 2 pound boxes for $10. ... the only 7018 rod they have is AC rod , it is 1/8 inch , price is $30 for 10# which is good... but there is NO SPEC listed.... If you only have a AC welder and your doing tractor brackets and frame work, that might be OK... I prefer a DC rod , 3/32 dia and meets the AWS-5.1 SPEC for E7018 .... Thats what Boilermakers and others use that have to pass xray and bend tests for strength..
Edited by steve(ill) - 19 Mar 2024 at 4:41pm |
Tbone95
I would have loved to see some strike an arc that day. Steaks and beers on me for sure ! |
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3301 |
lincoln excaliber 7018 or atom arc 7018 and lincoln 5p+ 6010 will do every thing almost iwould not mess with 6011 6013 personally, also good to have alittle 316l or 312 stainless and a little bit of nickle and you can do almost any thing
Codger
I still prefer the old Lincoln 6010 "Red Rod" myself when it comes to that electrode. I keep 5/32, 1/8, and 3/32 and it still comes in handy when putting something back together in a field. Throws trash everyplace but boy does it dig and freeze fast. Tried the 5P+ but really didn't get along as well with it. In fairness probably operator error as I'm very comfortable with 5P. 7018 is usually Excalibur but I have some Hobart tins around too. Also some Atom Arc, (ESAB). Have a little bit of Stoody 31, and 35 also for hard facing. Purchased some Ni 55 Lincoln nickle rod years ago to put a turbocharger mount back onto an exhaust manifold and it's held up very well being still there. Lot of pre, and post heating to make that one work.
HudCo
that red rod will really blaze through some bad stuff, i still use it when cleaning is not an option. but the plus seams to be alittle more flex able when tacking and does nice on the real thin stuff when the dig is turned way down . experance does make a big differance allways weld up hill and pay attenion to the edges of your puddle to make sure your slag is on the outside
Coke-in-MN
5 P was what used in shop at work as the old square Lincoln DC welder was main unit they had as it was all fitters would use for pipe welding , then brought in those Lincoln vertical Torpedo welder and hooked to high frequency for welding stainless and titanium tanks we had .
Had a sales buy come in selling Certanium Co welding rods said we only needed his rod and could do away with any other rod we stocked as it would replace every rod on our shelves - 1970 price was $18 a pound in 20 pound pack - heck that was beyond the price of full supply we kept for 20 pounds of rod . His selling point was welding a file to some mild steel and opposite side of flat file to a piece of stainless . Just told him next time I needed to weld a file to something I would order a pound from him Edited by Coke-in-MN - 20 Mar 2024 at 1:45am |
Codger
I've never had employment in a production facility of any kind. Always been a repair type individual. This always gave me the ability to zero in on what works, not what makes someone in management happy at least cost. Have used many different brands of electrodes and wires over the years both specialty, and run of the mill. Proper prep, and fitup work yields the best output no matter how it's looked at. I have older welding machines. All are long paid for from the get go of acquistion and have long been expensed/capitalized out as assets. I should probably purchase a new & modern unit, but can't bring myself to replace something that is not worn out and works with a flip of the switch. I really don't weld enough any longer to consider the cost savings of running long term, (power consumption) given the cost offset or upgrading.
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3894 |
I buy the rods in a plastic box just throw them on the rack with the welder. Neither the old miller or the new China welder seam to care what rods I'm using.the new welder has both hotstart and high frequency star so it'll start anything I've been using old rods that have been in the shop for years. My shop is heated and air conditioned so there really isn't any temp fluxuation.
