Running with choke on |
Post Reply | Page <12 |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77986 |
Some inline filters have a RESTRICTION or a CHECK VALVE that takes a couple PSI to open... You want the OLD FASHION filter that is gravity feed and zero restriction.
resurrection20
Bronze Level Joined: 14 Nov 2023 Location: Oregon Points: 77 |
Remember how in that first pic I uploaded the carb was wet and that screw was loose? It was wet all around like that, but it could have been leaking out of the breather tube and running back. It was really hard to tell there was so much. Couldn't get the breather tube off because it's so short. If it was leaking out of there, I found something there to tighten up, at least. When I first got it, it'd run fine for about an hour and then you'd need to start choking. A slowly sinking float makes sense. Carbs never cut me any slack. |
resurrection20
I...had no idea. That explains that brand new Wix not doing me any favors. The old, partially plugged filter was actually helping me by restricting flow. Edited by resurrection20 - 19 Mar 2024 at 8:16pm |
resurrection20
You're gonna laugh. So, I had put non-ethanol 92 in it because that's just what I had around for my small engines. I ran it out of fuel yesterday working and went to get some today, except I went for 87 10% ethanol because I'm not made of money. It started running normally again...it's always been a little belchey/uneven and always liked some choke. I bought it running and driving for $500 and was using it the next day- so I didn't really complain that it didn't run perfectly.
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3158 |
Sooo…was your supply of 92 small engine gas from last year?
remember the "B" has about 6 to 1 compression ratio compared to a car that has 9 to 1 compression ratio... B should run with some pretty crappy fuel.. Higher octane will retard the spark to the plugs... that could be a possibility ??
but that will not fix the LEAK........ you still need a rebuild in the near future. Edited by steve(ill) - 21 Mar 2024 at 3:34pm |
-----GOOGLE--------What happens if you put 93 gas in a 87 car?
Engine computers can usually adjust their timing to account for the increased octane levels, so if you put premium gas in a regular car, you probably won't notice anything. However, some engines are not designed to burn higher-octane fuel, and you may see a reduction in performance and fuel economy. Edited by steve(ill) - 21 Mar 2024 at 3:37pm |
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4415 |
Ethanol has sort of a natural cleaning effect, so it may have actually cleaned the carburetor out a bit. If you are using the tractor every day, running ethanol isn't a problem, except it tends to deteriorate rubber parts.
The biggest problem with ethanol in old engines is when it sits for extended periods.
resurrection20
If was less than a week old. I got it to start mowing the lawn. |
resurrection20
Not leaking anymore, either. I ran it for about five hours straight today with no problems. Mowed blackberries, dragged fallen limbs and other stuff around to make a burn pile. I knew using the wrong octane was a waste of time/money in cars- I didn't think it'd matter on an old tractor, but I learned something. I use the 92 non-ethanol in EVERYTHING that doesn't go on the highway, just so I don't have to deal with ethanol drama. This is the first time it's ever been a problem! Edited by resurrection20 - 21 Mar 2024 at 9:53pm |
resurrection20
I usually drain everything and run the carbs dry. When I can't, I use Sta-Bil and have never had any problems. |
