Metal cutting bandsaw
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Topic: Metal cutting bandsaw
    Posted: 25 Jun 2023 at 11:17pm
I bought myself 1 the other day. It needed the motor rewound and a 3" wheel. Motor is done and wheel is on it's way. This is one of the ones every blacksmith had in his shop back in the 1960,70's, etc. I want to buy a new blade for it. Do you fellows have any recommendations on a blade. I'm gonna order the rubber band "tires" for the steel drive wheels from Amazon
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 5:40am
I have an HF Wells industrial bandsaw and have found Lenox band saw blades to be about the best if correctly selected for the job at hand. I've ordered from here in the past as well and coolant and such:
Edited by Codger - 26 Jun 2023 at 5:41am
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 5:48am
I completely agree with Codger. Lenox are very good if the proper blade is selected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 5:57am
I had two of those 'offshore' 4b6 bandsaws but do to the move now only one...
I've used the 'bimetal' blades from one mfr(name I forget..)  for 30 years and never had to adjust the 'track' of the blade.Used to cut a LOT of steel years ago, today not so much.
bottom line, buy a quality blade,keep 2 on the shelf !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 6:20am
"Morse" brand saw blades are decent to good also and more easily available at the home centers, (around here).
I always run coolant so blades last much longer than dry cutting saws.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 6:52am
What band saws do you guys use?
Like the price point but have seen some negative reviews to it being China Built
More money but probably a little better quality
What do you guys think?
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 9:26am
I bought a 14 inch vertical wood band saw about 40 years ago. ($200)... Built a jackshaft with couple pillow block bearings and a couple BIG and SMALL pulleys.. Reduced the speed 15 to 1 or better i think.... It was 14 inch wheels and uses a 92- 94 inch blade... I agree with the BI-METAL blades... i dont use coolant...... i need the standup because i cut a lot of smaller parts / sheet metal , and that cant be clamped in the horizontal unit..... but i guess some of them tilt up and you can use the table..
they make some similar now that have gear box and reduced speed for metal... Pushing $1500- 2000.. i think.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 7:26pm
MK MORSE is a great company, and based in Ohio I believe.
