7020 oil leak between front plate and engine |
DIESEL
Silver Level Joined: 26 Aug 2013 Location: Sandhills Points: 259 |
Posted: 07 Feb 2023 at 6:26am |
I've got a 7020 that has developed a pretty significant oil leak between the block and front mounting plate. I've never tackled this repair before, not sure I want to. How big of a job is it, I assume that I'll need a jack under the front of the engine to support it. Might have to loosen frame rails a bit and will I pull the camshaft out, or just pull the gear off. Thanks for any help.
MACK
You will need to rebuild or replace front plate and dowel pins. Not a small job. MACK
