Turbo WF |
NextGenAllis
Bronze Level Joined: 30 Jan 2023 Location: New Ulm, MN Points: 4 |
Posted: 06 Feb 2023 at 11:27am |
Question if anyone has ever put a turbo on a WF. I have one from work off a yanmar diesel. Small Turbo. The machine it came off of is getting a new one cause the old one i have is "locked up" and the seals are bad. There is no core charge on it, so i was going to keep it and rebuild it and hopefully throw it on my WF as a fun little project!
DSeries4
Anything is possible with enough time and money. You would have to build a completely new manifold to accommodate it. The low oil pressure system in the WF might be a problem keeping the turbo properly lubricated and cool. Sounds like a lot of work for little reward. If you want a turbo on your WF, Keystone builds a kit that is pretty much bolt on. In your case, you would have to make everything from scratch. Personally, I could spend my time and money on other projects.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77846 |
I think the lack of adequate oil pressure would be my main concern..
MACK
Turbos have a orffice to limit the amount of oil. MACK
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4423 |
From My personal experience I'd be concerned about the weakness of the bottom of the block at increased power. I've seen more than a few of the 226 blocks with the main caps shattered and the supporting areas of the block destroyed. As Mack said , even though turbos need to be oiled, the smaller ones don't use muck. Were I to turbo a 201/226 block I would refit it for a full flow filter system and build in some added support for the crankshaft mains.
Now if you just want a toy that has a whistle without performance get a Keystone kit and have fun.
corbinstein
Orange Level Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
I'd call it Turbo WTF, or Turbo t**d.
MACK
PaulB is correct, much power and it will pull the main webbing out of block. Been there. MACK
