Flail mower operation |
TomYaz
Orange Level Joined: 14 Sep 2009 Location: PA Points: 10319 |
Posted: 05 Sep 2021 at 7:50pm |
Is it SOP to have a flail mower just "float" on the ground or is it held at a height via two way hydraulics?
Reason I ask is I want to put one on my D17 series One....with the flail offset feature I want I will need to finagle the hydraulics to allow independent operation of the offest. Want to know what I would need for the up/down movement .....2 way or will letting it float suffice...
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78043 |
I dont see why you would need DOWN pressure... Float down and raise up to the position you want to hold... Just like the rear blade / plow on an old tractor.
TomYaz
Yeah thats what I am thinking too...
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41219 |
I used both a Ford flail and a couple other brands and set them so they run with light pressure (weight of mower) on rear roller but 3 point is handling most of the weight .
You have to allow the mower to move up and down so it follows the contour of the land and the movement of the tractor . |
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8850 |
I use a 9' wide Matthews Company Rotary Scythe. It is very heavy. The Rotary Scythe has balance springs and a roller, to help against scalping. With the Rotary Scythe in the fully raised position, it is easy to fluff wet hay.
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29673 |
Helped a cousin set fence on his Uncle's Hemp Farm year ago summer, he had a flail mower but was not doing very well with it where looked more like a flail tiller
Coke-in-MN
The Ford flail I have not takes about 1/3 more HP to run that the Mott I use to have , Mott used 2 L shaped cutting blades that hung from a U bracket , Ford has a 1 piece blade - heavier and just doesn't cut as well
Walker
Orange Level Access Joined: 12 Sep 2009 Location: oh Points: 8102 |
Rear roller is the right answer for the ones I've ran.
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3211 |
Got to know your fail type?
If Fail mower has a REAR ROLLER, then yes flail mower housing might be able to be pitched upward IN FRONT so it’s blades clear ground while also resting(traveling) on rear roller? If fail mower DOES NOT HAVE REAR ROLLER, then either a manual ratchet(3pt upper screw) or hydraulic cylinder can set blade heights. Some flail brands have SKIDS located at each of its housing sides? If so, then skids might be adjusted so blades may still clear ground if mower bottoms out...- hopefully bottoming out on skids. I have an IH60 15’ flail. It is pull type, 2 rear tires, no roller, manual ratchet cylinder that I set so it’s outer skids just touch. As long as ground stays level all is good. But if ground has an significant terrain, blades can quickly tiller up sod. Edited by AC7060IL - 08 Sep 2021 at 8:51pm |
