Flail mower operation
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: Flail mower operation
    Posted: 05 Sep 2021 at 7:50pm
Is it SOP to have a flail mower just "float" on the ground or is it held at a height via two way hydraulics?
Reason I ask is I want  to put one on my D17 series One....with the flail offset feature I want I will need to finagle the hydraulics to allow independent operation of the offest.  Want to know what I would need for the up/down movement .....2 way or will letting it float suffice...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2021 at 9:09pm
I dont see why you would need DOWN pressure... Float down and raise up to the position you want to hold... Just like the rear blade / plow on an old tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 12:12am
Yeah thats what I am thinking too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 12:39am
I used both a Ford flail and a couple other brands and set them so they run with light pressure (weight of mower) on rear roller but 3 point is handling most of the weight .
  You have to allow the mower to move up and down so it follows the contour of the land and the movement of the tractor .
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 9:46am
I use a 9' wide Matthews Company Rotary Scythe.  It is very heavy.  The Rotary Scythe has balance springs and a roller, to help against scalping.  With the Rotary Scythe in the fully raised position, it is easy to fluff wet hay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 9:57am
Helped a cousin set fence on his Uncle's Hemp Farm year ago summer, he had a flail mower but was not doing very well with it where looked more like a flail tillerLOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2021 at 4:26pm
The Ford flail I have not takes about 1/3 more HP to run that the Mott I use to have , Mott used 2 L shaped cutting blades that hung from a U bracket , Ford has a 1 piece blade - heavier and just doesn't cut as well
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2021 at 5:36pm
Rear roller is the right answer for the ones I've ran.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2021 at 7:21pm
Got to know your fail type?
If Fail mower has a REAR ROLLER, then yes flail mower housing might be able to be pitched upward IN FRONT so it’s blades clear ground while also resting(traveling) on rear roller?
If fail mower DOES NOT HAVE REAR ROLLER, then either a manual ratchet(3pt upper screw) or hydraulic cylinder can set blade heights.
Some flail brands have SKIDS located at each of its housing sides? If so, then skids might be adjusted so blades may still clear ground if mower bottoms out...- hopefully bottoming out on skids. I have an IH60 15’ flail. It is pull type, 2 rear tires, no roller, manual ratchet cylinder that I set so it’s outer skids just touch. As long as ground stays level all is good. But if ground has an significant terrain, blades can quickly tiller up sod.
Edited by AC7060IL - 08 Sep 2021 at 8:51pm
