840 wheel loader |
53 ca
Bronze Level Joined: 17 Sep 2018 Location: SEMO Points: 14 |
Posted: 23 May 2021 at 3:53pm |
have a 840 b wheel loader that we changed motor and hydraulic pump on. Also changed transmission fluid. Now it will not pull itself up any grade until it gets warmed up. say about 10 to 15 mins of run time. what fluid should I have used in it ? THANKS for any info. Jerry |
orangeman
Orange Level Joined: 12 Sep 2009 Points: 1694 |
Jerry: the information on the hydraulic fluid should be covered in the 840 Articulated Loader Operators Manual Form SV-112B - Part No 1012879-1. Unfortunately, I don't have that in doc. in my periodical library.
If the fluid is not the problem, it might be good to start with a clutch pressure check or could be also worn splines on the Torque Converter Pump drive, flex drive plate failure or low clutch pressure which would occur as a result of a weak regulator valve spring or regulator spool sticking. The later could be remedied through removal and cleaning possibly. The Service Manual for the AC 840 wheel loader is form No. ISM-17 and part number 1013042-5. Orangeman
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78075 |
are you sure the level is correct ??? ....
53 ca
pretty sure it is good. Just for the info how do you check the fluid level? I was told to use Dextron ATF . Right or wrong?? I will check fluid when I get by the loader this week. Thanks, Jerry
reply #25 says there should be TWO marks... running, and motor off ??
53 ca
Thanks for the info, When I get back to the loader I will do some more checks and see where things are. Where can I get a service manual for it? Thanks again |
e-bay.............. not cheap
Ian Beale
Orange Level Joined: 03 Oct 2011 Location: New South Wales Points: 934 |
Not expensive compared to what might happen without though
