D15 Revival |
Post Reply | Page <1 891011> |
Author | ||
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10573 |
The pin needs to be longer. I would use a cylinder shaft rod, hard on outside with soft center core. You can weld a bolt to bushing to get it out with slap hammer. McMaster Carr has the shafting. HTH Tracy
Sponsored Links | ||
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2599 |
Been following your post as I have a D 15 I'm working on . Wonder what kinda seat you got ? Mine is very sad . Glad you are making progress .
Jk chalmers
Orange Level Joined: 19 Apr 2018 Location: Delaware ohio Points: 295 |
As long as the metal is good You can get a pair of cushions from eBay for $88 can’t beat that searched everywhere...!!
ACinSC
Pan seat is gone . Previous owner put a ratty lawnmower seat on .
modirt
Orange Level Access Joined: 18 Jul 2018 Location: Missouri Points: 6733 |
I believe the seat is just like this one, which includes new cushions installed on new metal backing plates. Price was a bit less as it came from A&I. With a seat like that, better keep the tractor indoors. And keep the barn cats and coons off it too! Edited by modirt - 10 Sep 2018 at 6:58pm |
modirt
Do you have a link to the exact shafting you describe? I've been to the MC site and a guy could get lost in there for days. And there was a lot of discussion about making the pin longer than the original and replacement pin, as it needs to be longer to ride along the full length of the bushing. So if an alternative could be found, it would be welcome.
ACinSC
Nice seat . Maybe one day . Gotta get my starter back from Steve and get my old tractor running again first . Doubt a cat or coon would wanna sit on this seat .
Tracy Martin TN
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3214 |
MoDirt, I've enjoyed following your post - thanks. Has your harvest taken over? Any further progress on your D15?
modirt
I was by the shop yesterday. Rear wheels are back on, engine is back in (with new clutch and ring gear), rebuilt starter is back on, etc. Still waiting on welder and front axle to finish putting it back together. Since tractor has been sitting, at least a quart of oil has leaked out of the rear axle. That is in addition to a small leak I found while she was sitting in my barn. Once she is back together and running, we will need to find the source of both leaks, but also to find out if the transmission is good, or if she jumps out of gear. Stay tuned!
JayIN
Orange Level Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
Ok!!!!
1852 Moore Farm
Bronze Level Joined: 21 Apr 2016 Location: Missouri Points: 91 |
Was able to stop in last week and check your project out. A lot of work going on with that old girl...It will come together pretty quick.
modirt
As promised.........an update. Thanks for forum member AJ, who agreed to part with a good usable front end (in exchange for some paper with pictures of dead presidents printed on it), she is back on all 4's again. Back from the dead! Even more better, not only did she start, this time she moved! Amazing what a working clutch will do. There are still issues to resolve, but we were able to take her a lap around the parking lot. Everything we tried was working, and on the brief run I had, she did not jump out of gear. We are getting there! |
modirt
PS: That was likely the first time she moved under her own power in about 20 years. There is video..............not that I would tease you or anything like that.
1852 Moore Farm
Nice.
chaskaduo
Modirt is doin the Treasure of the Sierra Madre Jig https://www.youtube.com/watch?v=H9E-01dK5zQ
modirt
Close to it, and as the bills start coming due, the part about being pretty dang stupid ain't far off either! On the plus side, with all the major stuff out of the way, she should be good for another turn around the track. She does run pretty sweet. (Nothing like the smell of new muffler paint burning off in the morning). |
modirt
So chasing down the source of the rear oil leak. A few months back when I was topping up fluids, a leak popped up under the back axle. So I found and tightened one of the large bolts that holds the hitch assembly on. The bolt head can be seen in this photo, above and left of the drawbar pin and directly above the sway chain bolt......its the gray bolt head with oil dripping from it.......... So it has started leaking again. The question I have for informed D15 gurus, is there an oil reservoir above the threads of this bolt that is the source of the oil leak.......OR......is that supposed to be a dry hole that is not dry....... instead, it has oil leaking into it from some hidden source, that oil then seeping past the threads and onto the ground? Also, is it common for these bolts to work loose, allowing the whole hitch getting sloppy loose from wear from flopping around?
Edited by modirt - 03 Oct 2018 at 4:30pm |
modirt
I guess the question is, if we pull that bolt, are we going to dump the rear transmission oil out? OK if we do, as we are changing it anyway, just trying to understand the source of the oil.
modirt
This bolt.......... |
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50731 |
The factory 3 point, that you have is prone to loosening, keep those 3 vertical bolts tight. I can't remember if they are dry or wet. I'd take the wet one you've wrenched on, before, out, with a bucket underneath, just in case... Then clean it up good, put some locktite on, and assemble, with a new lock washer...
Problem with d-17's and down, factory 3 points are held on with those 3 vertical bolts, and side to side stresses, on the 3 point, can move them bolts enough, to start them backing out. Add to this, the fact that all oil leaks head toward them bolts, and you have a serious flaw, if you don't check them, at least, each time you hook up something heavy...
Edited by DiyDave - 03 Oct 2018 at 5:44pm |
modirt
OK....here is what we found out. First, the bolt shown in the photo is not supposed to be a bolt. Parts manual shows it to be a stud with washer and nut on the bottom. Stud is to be coated with sealant, then screwed into place to setup. Once set, nut goes on. Reason for the sealant is the hole opens into the transmission case. When we pulled the bolt, the entire contents of the transmission dumped into a bucket. So the original stud was long gone. It had been replaced with a cap screw like the other three that holds the 3 point hitch and drawbar bracket on. Cap screws 3" x 3/4" Grade 8 machine bolts. The one we had had not been locked in place with sealant. Stud has a part number, but is no longer available from AGCO. An odd thing, so not available locally either. Next step is to check McMaster Carr. If none shows up, new cap screw is going back in. Still don't know if the other 3 cap screws, all of which are firmly in place, also open into oil reservoirs or dead end in space, but all three are going to be replaced and locked in place just the same. |
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Updates?
modirt
Sorry.......since the last update, there were two different related threads about this............. The mystery of the stud........ https://www.allischalmers.com/forum/looking-for-a-stud_topic154648_page1.html And an issue with the factory 3 point hitch casting....... https://www.allischalmers.com/forum/d15-3-point_topic154856_page1.html If all goes as planned, she may be put back together and running in the next week or so. We have about run out of known issues to fix. Either that or its the calm before the storm!
chaskaduo
Good to hear Mo (Howard).
acd-17
Bronze Level Joined: 12 Nov 2012 Location: Michigan Points: 30 |
Is everything coming together?
modirt
Things are still in limbo.........casting and related 3 point parts still at the machine shop. Hopefully, they will get to all that soon.
Dandan111
Bronze Level Joined: 01 Mar 2015 Location: Indiana Points: 152 |
Nice seeing you get your tractor to a solid state. It's hard to know were to stop spending money on a old tractor. looks like you've made some good decisions to me so far. That tractor will be around a long time now. Good luck as you finish her up!
modirt
It has been a while since I've published any videos......... [TUBE]xlltrrTxxLs[/TUBE]
exSW
Two thumbs up.
