Allis 8050 engine build
 Post Reply Post Reply Page  <1 345
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 10:15pm
Our 8030 fires as soon as you hit the key even without the throttle open, I only open the throttle in colder weather. So I will say it starts easy but it does like to smoke especially if you put a load on it.
If fishing is a sport your looking at an athlete
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 11:00pm
My 8070 had 4900hrs on the clock when I got it.No gov action below 1500rpm and wouldn't start hot without the bucket of water trick.O/H'd the oil drinker and put an A pump on it with M&W style pistons/sleeves.Fires on first stroke @30deg F.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 9:37am
This is a factory built 3500 MK II industrial engine that I installed in my 220. Minemec pump-starts real good. 190 hp on dyno with factory pump setting.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 11:00am
Calvin, where is the shut off on that pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 12:32pm
Jordan I believe it is on back side opposite throttle lever.One on the 301 out in the shop,I could go look.Mine uses a pull cable.Pull is on ,push is off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 1:23pm
It is a pull to run - push to stop mechanical control.  The diaganol bracket that you see
on the running engine holds the control cable.
Edited by Calvin Schmidt - 12 May 2015 at 1:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 10:05pm
Thanks, I see it now.  Little different setup than what Ford used.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2015 at 1:28pm
Well as some may know, I was having trouble with it warming up while working it. I believed the problem to be the new thermostats from agco. I had the old thermostat housing from the 8030 that we had put a intercooler on. Took the newer original thermostats from that and put them in the 8050. Now she runs just like it should. Moral of the story is that these engines need more coolant flow than what the new thermostats from agco can provide. Ones like the old original are from Mr. Gasket 4367 180* Stat.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2015 at 6:27pm
I put a set of the M&W Power seal piston and sleaves in my 7060, i believe they were called, Starts easy, my 8050 has an agco overhaul kit, it starts okay, plenty of power and little smoke. Before the M&W kit, the 7060 started so so.
If i could find a M&W overhaul kit i think i would buy it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2015 at 6:20am
Just thought id give you guys a update, I've put a good hard 60 hours on her and she has been running great. Finally done with planting, so hopefully I will have time to get it on the dyno before haying.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 1:22pm
Well it's been a long time, but finally got the old girl dynoed. 210hp with 28 pounds of boost. It will be getting tore back apart for a cam and flywheel swap in the coming weeks. Then redynoed without changing the fuel. More to come.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 2:51pm
Interesting thread. Lots of good info and pictures. There's a lot that goes into these diesels to say the least!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 4:29pm
Sent the cam to Vogel manufacturing to get the cam reground. Hopefully it's back in a week or two. It's busy season for them.
JCFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 9:05pm
Got to reading this thread and realized it was the one from 2 years ago. Had me all excited you was starting another build thread.
Guess all that new marriage stuff took all your time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 4:04pm
Cam is on its way back. Got new lifters, the 7040 flywheel is at the machine shop to be ground and pressure plate is ordered. Hopefully start on the tractor later next week. Working on a couple 2006 Cummins engines for a guy then working on the wife's little pickup.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:15pm
So what am I missing here? Why are you tearing it apart again to change the cam and fly wheel? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:17pm
Hopefully better torque, better fuel economy, less smoke with the cam. And hopefully the heavier 7040 flywheel will be better on the chopper. Like a big flywheel on a square baler.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 11:55pm
And now over a year later, has it been dynoed since the cam grind?
  This was definitely an interesting thread.
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 4:33pm
oh ya  this is what i was looking for  thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 5:01pm
I forgot about this thread. Yeah I did redyno it. No more power but it had less boost, So that tells me it's moving more air in and out so less heat. Went from 28 psi of boost to 22-24 psi. So Less restriction. I believe it had more torque on the chopper, but nothing like having a counter balanced crankshaft. Would love to find one and swap it in. Thanks for checking up on me guys!
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 5:42pm
Does it burn cleaner with the new cam grind?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 5:46pm
Somewhat. Still playing with getting the A pump set up just right for my liking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 9:38pm
I have the A pump on my 8070 set at 32 degrees BTDC, it smokes just a light haze under full load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 10:24pm
talked to you on phone once Kevin...Think mines at 32 also but smoke more than that.Has tips for the 4wd 426 (7580?) Don't know if that would matter. HP is 220 but it hazes under light load too. Pump guy went through torque capsule last spring and helpd some but never clean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 10:26pm
My timing is around 28* I think. Maybe I will set it up a tad and see if It cleans up some. It's smokes pretty good under full load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 1:53pm
Ok guys I'm going to update this thread. I never could get the thing to stop smokimg so much. I couldnt figure it out. Started to really piss me off. I emailed Dennis at Fair valley performance this spring and talked to him about it. He recommended I turn the torque capsule in a half turn. If it made any difference I should give it another half turn. Well I did and it didn't make any difference. So now by this time I was really getting pissed. So after 1st crop I took the pump off and injectors out and set them to him. Now before I built the motor, I took this pump to my local diesel shop. K&S fuel injection in weston wi. They said they balanced it and set it to 8070 rpms and to 140cc as I specified, and told them it would be on a farm tractor. Well.... Dennis calls me... pump is way out of wack. High variance between all cylinders, set to around 155ccs and the torque capsule wasn't even doing anything. It was just there for the ride... injectors tested good. So he cleaned them and repoped them to a little higher pressure and reset the pump to the proper specifications. I get it back, put it on and let me tell you WOW! what a totally different tractor! Thus thing not only has the power it did before, but it has some BALLS! Before it would come under load and kinda just slowly die off. It finally has some torque rise now. Lots less smoke. And like I say, TOTALLY DIFFERENT TRACTOR! so in short, never doing business with k&s again.
