D-17 gas gauge float |
22-shotgun
Topic: D-17 gas gauge floatPosted: 20 Dec 2015 at 12:04pm |
Hi all, I'm new to this site and the Forum thing. I have a great little D-17. My question is trying to find something to replace my gas gauge float. I was told cork will not work with the ethanol in the gas, that's probably why mine sinks and coating it with something will just disintegrate off. Thanks for any help
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24876 |
Posted: 20 Dec 2015 at 1:10pm |
I just use 1/2 of a float from the junked Cavaliers I've disposed of around here. Now you can buy new floats but well I'm cheap AND frugal ! I even found another complete fuel sending assembly(pump,float,etc.) today when I kinda cleaned up here,yeesh....maybe I'm a packrat ??
Jay |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3595 |
Posted: 20 Dec 2015 at 1:45pm |
There is a guy in IL that sells floats for some kind of model (maybe an A ) Ford.
I I lost his ID, but got one for the D 15. I swear D series 4 gave me the source. |
Stan R
Posted: 20 Dec 2015 at 2:21pm |
This is what I used 10 years or so on our D17 IV. http://www.macsautoparts.com/ford_model_a/model-a-ford-gas-gauge-float-modern-neoprene-improved-compound.html |
Gerald J.
Posted: 20 Dec 2015 at 4:55pm |
Cork will work fine if coated with SealAll. Has been working for me for decades on the float in my MF-135 that runs fine on E10.
Gerald J. |
Norm Meinert
Joined: 31 Oct 2010 Location: Davis illinois Points: 470 |
Posted: 20 Dec 2015 at 8:36pm |
I sell the new floats.
Johnwilson_osf
Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 944 |
Posted: 20 Dec 2015 at 8:42pm |
22-Shotgun, welcome to the forum. We love to see pictures, so keep us posted on your D-17. I can't help with floats, but glad to have you on the forum.
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7569 |
Posted: 20 Dec 2015 at 9:28pm |
Are you sure your float is sinking? If it is reading empty, the most likely cause is the float riding up and down on the rod rather than staying at the end of it where it belongs.
If your float is still bad, I use new ones that are made of neoprene (will not disintegrate in gas). There are around $4 a piece from a place called Old Standard Auto Parts - the carry stuff for Ford Model A's. Their number is 866-654-2855 Edited by DSeries4 - 20 Dec 2015 at 9:30pm |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 21 Dec 2015 at 8:10am |
to the forum!! Where bouts in MN are you? Best bet is what DSeries4 told you.
Dave H
Posted: 21 Dec 2015 at 4:28pm |
When i called that guy up about a float he chuckled and remarked, You must have some kind of AC. ![]() |
CTuckerNWIL
Thanks(1)
Posted: 21 Dec 2015 at 4:37pm |
I picked one up from Kevin last spring when I planned on taking the tank off to clean it. After removing the gauge, I placed the outside end of the "wire" on an anvil (back edge of the vise) and tapped on the swedged part to bring it back close to round. Slide the old float off along with the retaining washer and slide the new Neoprene float on. Replace the washer and place the "wire" back on the anvil and hammer lightly till the washer can't slide off.
After I got done, I thought " I should have taken pictures or video" Oh well hind sight is always better ![]() |
22-shotgun
Posted: 08 Jan 2016 at 10:19pm |
Thanks everyone for the help. DSeries4 it's not sliding on the rod, when I looked in the tank it was below the gas level. Will give the neoprene a try as Minnesota requires gas to have ethanol in it. Ted J, Fergus Falls.
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 09 Jan 2016 at 7:13am |
I'd get one from Norm.
Dusty
