Cam bearing tool
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Topic: Cam bearing tool
    Posted: 12 Sep 2015 at 4:29pm
Hi,
What are you using to remove cam bearings in a B engine?  special tool?  make your own?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 5:34pm
Search Youtube, here's 1:
[TUBE]http://youtu.be/NPlCr7PZCUc[/TUBE]
Edited by DiyDave - 12 Sep 2015 at 5:35pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 6:27pm
You can take the block to the machine shop, engine re-builder or maybe the local parts store will rent one like this one, it expands tight in the bearing and keeps the bearing from warping as it's pressed in place. Please look at the pics before you replace your bearing.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 7:12pm
What ever you use don't forget to line up all the oil holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 8:09pm
Yeah, thats why I'm asking.  Got the block back from being sent away to a machine shop, they replaced the cam bearing- didn't ask them to do that but before I started putting the Cam back, I though I'd better check the alignment for the holes.  One was 1/3 and the other two not even closeAngry  If they have to be pressed in I guess I'll send it back....
Thanks
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 9:06pm
I have the same kit Don has shown above, and it works great.  Yeah it's a bit pricey, but you don't screw up bearings if you use it properly.
Still in use:
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 9:38pm
Use a long drill bit and redrill.   MACK
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 8:54am
Take it back to th machine shop they screwed it up let them fix it if they miss it up again its there nickel not yours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 1:48pm
O-no that's not good. You might do a test fit of the camshaft in the block if the cam fits OK, then I do just what Mack said, drill the holes through the cam bearings, clean the bearings from the drilling and retest the camshaft fit, if it's OK put her togather and don't worry about the cam bearing holes that are off.
I'm just thinking out-loud.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 5:51pm
It they are already in, I'd try drilling, if you can do it through the oil gallery/block.  Be sure to de-burr/countersink the inside surface of the bearing...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 8:32pm
If you send it back, they may drive them back out and reinstall them. Then they will fit block too loose and turn with camshaft.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2015 at 7:53am
Thanks for the info!!!
Thanks
AllisRocks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisRocks Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 4:52pm
I read this post too late and destroyed my first set of Cam bushings on my Allis Chalmers D14. (149 engine) I made this tool afterwards and it works great... about $5 to make from tractor supply. I lightly tapped them in. Maybe could press them in also using this tool.. The washers fit perfectly in the bushings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisRocks Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 4:54pm
This is a picture of it on the used bushing.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 8:14pm
What Mack said X2
