Narrowing up mounted cultivator
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Narrowing up mounted cultivator
    Posted: 07 Jun 2015 at 5:40pm
How do you narrow the units under the WD tractor. Its a four row mounted. All the others move in fine, but the center ones still seem to close to the row. Any ideas. Thanks
Adam
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 6:19pm
This is a cultivator designed for 40 inch rows and you are trying to use it for what spacing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 6:38pm
Sorry should have mentioned 30".
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 7:10pm
  MAKE YOUR OWN ADJ.  DOUG IS CORRECT WAS MADE FOR 40 -38 INCH ROWS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 7:32pm
It looks like I could take off two shovels and make it work. I thought I had read somewhere that these would go down to 30". Maybe I'm dreaming. Thanks guys
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 7:41pm
You can always convert it to a two row cultivator and do rows 1 and 3 the first pass and then turn around and do rows 2 and 4 the second pass. Most farmers stopped cultivating and went to herbicides when they switched to 30 inch rows.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 7:47pm
Adam pm me and I will send you my phone number I have mine set at 30" here's the INFO on how they set in to 30"
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 10:40pm
dad narrowed our 2 row to 30's.wasn't around when he did but I used it plenty.Talk about takin a while to plow corn!!I'ts all apart hanging on the barn wall.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2015 at 6:57am
I have a manual for the 4 row snap coupler cultivator. It says it ot will go to 30" rows, but I don't know about the mounted ones.
This page was generated in 0.067 seconds.
