Looking to buy a 7020
brads180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brads180 Quote  Post ReplyReply Direct Link To This Post Topic: Looking to buy a 7020
    Posted: 06 Feb 2015 at 8:39pm
Looked at two today one p/s and one p/d trams. Both have cosmetic issues. Which transmission would be best for light field work.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 9:04pm
power shift is better for all field work. Put your finger in the blow by tube and taste/smell for antifreeze is the first thing I would do...
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 9:15pm
make sure it has a water filter on it. either tranny works well.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 9:31pm
X2
And take some test strips for checking the coolant pH to see if the filter has been changed when it should.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 9:35pm
http://www.auctiontime.com/OnlineAuctions/Details.aspx?OHID=9181883&lp=th
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 6:35am
I bought a 7020 power direct last summer, used it to chop 350 acres of stalks last fall. I like the tractor. We have 2 8050 ps, so I didn't know if I would like the pd or not. The advantage of the pd is the selection of gears. In the working speeds, the 7020 has 6 or 7 gears in the 4 to 7 mph range. The power shift is much more limited. But if you are constantly changing speeds (baling, raking, hauling manure, fertilizer grinding feed or such), the ps is the better tranny. Tractorhouse websit has the charts for the ps and pd trans for the 7020 to compare.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 7:17am
Sorry that wesite is TractorData.com
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 8:39am
I've only seen 1 but they made a 16speed PD; I'd proly not give that tranny as high of marks.   It just had 4 forward gears instead of 5. I love my PD for field work and love my PS for loader work.   now when I find one with FWA; i'll be in heaven!
Alex (wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex (wi) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 8:35pm
We have a 7020 Allis Chalmers.  One way to check the head gasket is to start the tractor and run for about 2-3 minutes, shut it off and remove the radiator cap.  If there is compression leaking into the cooling system, you will hear a "puff".  It's kind of a tricky test to do, because it does not take long for the cooling system to pressurize from normal warming of the engine.
~Alex
pohlman249 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pohlman249 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2015 at 5:04am
My dad's 7020 is a 16 so PD.. not a whole lot different to drive than my uncle's 7010 20so PD.
This page was generated in 0.065 seconds.
