B Model - sputtering under load |
Bill Myers ![]() Bronze Level ![]() Joined: 22 Jul 2012 Location: Lilburn, GA Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jul 2012 at 3:38pm |
Good afternoon -
I have a B Model that started sputtering when under the load of the finish mower. There was some dirt in the gas bowl which I cleaned and changed the fuel filter. I cut for about an hour this afternoon and it started sputtering again. Ran fine back to the barn, but each time I tried to engage the mower, it sputtered and nearly cut out. The gas bowl is still clean and the filter looks clean. Any ideas? Thanks, Bill
Rod B ![]() Orange Level ![]() Joined: 25 Jul 2011 Location: Peoria Points: 415 |
Crud in the gas tank. Sounds like the engine is running out of fuel under load. Take the sediment bowl assembly out and clean the tank, check the line and double check the main jet in the carb allong with the other straight foreward things.
Will do. Thanks!
ctbowles58 ![]() Orange Level ![]() ![]() Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
As hot as it has been i SPUTTER under a load to.
Rog(NCWI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Aniwa.WI Points: 243 |
If you have a mag on your tractor, you may have a bad coil. I had similar problem and and found that the coil was bad on mine.
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1151 |
I have a model B that does this also. Mine was fuel line related. If I was a gambling man, I'm sure yours is also. Going orange is going great!
Boogerowen ![]() Orange Level ![]() Joined: 23 Apr 2011 Location: Mannford Ok Points: 431 |
Get your fuel system cleaned up and then listen to her purrrrr !!!
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22824 |
If it starts to sputter, pull the choke out some and see what it does.This is a pretty simple test to see if it is a fuel problem or spark problem. If choking helps it, start checking for a fuel restriction everywhere from the tank to the carb. If choking it has no effect, start with a complete tune up of the ignition system.
Edited by CTuckerNWIL - 22 Jul 2012 at 9:11pm |
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6442 |
Bill, first off welcome to the Forum. What has been posted is good advice. Also you might want to invest in a fresh set of Autolite 295 plugs if yours have a bit of time on them. BTW you are too close to "Hotlanta" for this old country boy. Jackson County is getting a little crowded for me too. Got two B's - one waiting on brake installation; one parts donor that I may get running for a spare.
Mrgoodwrench ![]() Orange Level ![]() ![]() Joined: 03 Apr 2011 Location: CHICORA PA Points: 2087 |
my c recently started doing something like that. it turned out ot be a loose rocker arm lash adjuster. it only seemed smooth with no load, i soon realized i couldn't get full speed out of the motor at no load. yours probably not that, more than likely fuel, just some food for thought
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11978 |
As "Tuck" mentioned, the choke trick works almost everytime if its a fuel delivery problem. When you pull the choke a little bit you cut the air to the engine and fatten the fuel mix. If the engine responds, its a fuel delivery or dirt or debris in the load side of the carburetor. Carb needs a roto-rooter....
Look at the screen in the fuel line inlet adapter. I've seen it choke and engine to the point it would only run for a few seconds every 10 minutes.
Gerald J. |
JarrodACFan ![]() Orange Level ![]() ![]() Joined: 24 Jan 2012 Location: Delaware Co. IN Points: 732 |
My "CA" started doing that a while ago. I replaced the governor return spring and it ran fine afterward. Maybe try that.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN |
thanks for the good advice. flushed the gas tank, lines, etc. runs like it is 1952! great tractor. i grew up with farmalls and JDs, never had anything "orange" but sure will keep this one!
Hey Hubert - yep a little to close to the big city but not for much longer. Looks like your a ff or medic...thanks for your service!
