Disc ? How Big for C
Post Options Post Options   Thanks (1) Thanks(1)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: Disc ? How Big for C
    Posted: 02 Jul 2012 at 9:45pm
How big of a disc would a C pull in Iowa dirt and getting it in the ground?
Thanks
Mike
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 6:34am
I have the 6 foot drag disc that Dad got new with the 47 C. He didn't have the C long but when he got the CA he put 13-24's on it so he could stay up on plowed ground to pull the disc. If it was any bigger than 6 foot, I don't think you could disc plowed ground. You could probably pull a little more in cornstalks???????
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 7:32am
I agree with the 6'. We used to pull an 8' disc with a B in light ground and it was more than what was good for the tractor.  I'm probably in the minority on this, but I prefer implements that are toward the smaller end of a tractor's capability, you can always go a little faster, but you can only go so slow when things toughen up.
Dick L View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 3:20pm
This 8 foot pull type disc was pulled over many acres with a C.
A six foot would be fine but I sure wouldn't turn down an eight foot disc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 6:07pm
Thank you all for your replies. Dick that is a beautiful disk! What kind is it? Did you restore it?
I pull an 8 foot Fergeson 3 pt disk behind my WD. I am not sure a C could get the traction to pull a 8 foot disk too deep in my ground...but maybe I would be surprised!!!
Should a WD be able to pull a 10 or 12 foot disk? What is all you AC experts opions?
Pastor Mike
john(MI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 6:07pm
I pulled a 8' IH drag disk around in plowed ground with an IH A.  Had plenty of power, so I would think a AC C could as well!
BrettPhillips View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 8:32pm
As long as the cooling system is in good shape, a healthy C does fine with an 8 ft tandem disc.  Dual rear wheels would be ideal, but may not be necessary depending on the soil.  Mine does well in second gear with an 8 ft JD KBA in most conditions.  These little tractors will make your neighbors stare in slack jawed amazement if you set them up right!
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 9:48pm
I pulled a 7 ft disc with my CA with no problem in third gear. I disked a field for a friend and he said I would have to use 2nd gear going up a hill in the field as he had to do that with his WD  when he pulled the disc. I pulled right up the hill in 3rd with no problems. I too feel it is better to have a smaller tool then overload the tractor. Bob
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 10:31pm
I have the 8' pickup disc with my CA and it pulls it very nicely over plowed ground.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 9:09am
 I pull a 8-1/2" mounted with a "CA" in plowed ground with no trouble in 3rd gear. I put duals on for a much nicer ride in plowed ground. Just keep in mind that a "C" is not a "CA". I have not ever used a "C". Below is a link of me discing with my "CA" in plowed ground. Who ever had this disc before myself put 18" discs on it.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 9:16am
Pastor Mike
Thanks.
That was a disc that my Dad bought back in the mid to late 1940's. It is an Oliver disc and I restored it winter be for last. I had to make some of the frame parts as well as machining John Deere bearings and spools to fit. I still need to find or machine channel to hold/mount the scrappers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 6:11pm
Dick thanks for sharing. You really do first rate work! What did you use to clean up the parts? Did you sand blast everything?
