Odd tractors and plows
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: Odd tractors and plows
    Posted: 26 May 2012 at 2:51pm
Some odd 4 wheel drive units in use , early attempts for more power .
Then notice at the 1 min mark the push pull plow on the tractor , using both ends at same time, Two way plows also seem common ..
[TUBE]http://youtu.be/aV3vUVaIgn4[/TUBE]
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2012 at 3:36pm
I am fascinated with european farming and how different it is from here in the United States.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 8:44am
At one time, my dad was seriously thinking about making a 4 wheel drive out of two D-17s.   Kind of wish he had gone ahead and built one.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 9:01am
My brother had a souped up UC Allis and souped up WD hooked up together, and pulled a six bottom plow with them.  Later he hooked up two 40 Cockshutts with duals and pulled an eight bottom Oliver plow with it.  We had to be careful on the turns because the back tractor would try to run over him.  Ford tractors had a factory kit for Ford 6000's and other Ford tractors for a tandem hook up.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 9:10am
Here is a video of a guy in Western Canada that used to make these types of tractors for people before the articulated 4WD tractors caught on.
[TUBE]http://youtu.be/ZhULmjuk4cE[/TUBE]
RockyBottomFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RockyBottomFarm Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 12:45pm
last fall I was bidding on a John Deere R That was the second tractor from a double setup, needed alot of work and a front axle, it had long rods over the hood that went to the next tractor for the hand clutch and throttle.  neat how people make some configurations.
My great grandpa built what they called a truck wagon/trailer it was a 2 ton truck frame that had the trans and rearend hooked up with the trans hooked to the PTO on the John Deere B.  had a hydraulic dump bed.  My grandpa said you could go anywhere with the biggest load even.  They used to use it to go to the river and get sand for mixing concrete.  they would shovel it full and drive home, went right up what we call the yellow banks.
38 & 41 B, sickle mower, 2 way plows, rear field cultivator, 2 row drill planter
40 Combine
66 Combine
Roto Baler
