D14 Bearings
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Topic: D14 Bearings
    Posted: 27 Apr 2012 at 6:10pm
I'm replacing the rod and main bearings on my D14. Does anyone know the torque on the caps and the acceptable oild clearance?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 8:14pm
Rod bearing clearance ..0.0006-0.0027
Rod nut torque (Ft.-Lbs.) ....35-40
Main bearing oil
clearance is 0.002-0.004. Install inserts
with projections engaging the machined
slots and with slots in cap and
block on the same side of engine.
Bearing cap retaining cap screws
should be tightened to 90-95 Ft.-Lbs.
of torque.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:18pm
My service manual list the rod bearings at .001-.003
also lock nut torque 40-60 inch lbs.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:31am
I'm within tolerance then. On the torque, I was guessing 45 on the rods and 100 on the mains, so I should be alright. Did the mains and 1 rod yesterday and a storm blew in.
Thanks guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 8:08pm
I finished the bearings this evening and went for a ride. 20 pounds of pressure and quiet. I happy now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 10:20pm
Clap
