D 262 / D-15D
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: D 262 / D-15D
    Posted: 27 Apr 2012 at 11:36am
HELLO
 AN ANYONE GIVE ME THE DEGREE TIMING ON THE INJECTOR PUMP I KNOW IT IS BEFORE TDC I JUST DON'T KNOW THE NUMBER OF DEGREES. THANKS THAD
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 11:39am
If its a d262 then it depends on the model of pump
if its a D175 in a D15D then I am not sure....
1968 D15D,1962 D19D
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 12:47pm
My service book shows 2 models of pumps on a D-15, both take 22 degree's static timing on the pump. Also, each hash mark is 2 pump degree's or 4 engine degree's. So keep that in mind.
Also as stated above, the 262 engine is a 6 cyl. for D-17/D-19's. The D-15 uses a 175CI engine with 4 cyl. The 175 engine is basicly a 262 with only 4 cyl's.
Yea, I can fix that.....
